strange_cat
- Joined
- 21 Oct 2008
- Messages
- 4
I have a Woking to Waterloo monthly season ticket. Is this ticket valid to travel via Weybridge if I want to break my journey at Richmond and Putney (also on the Waterloo line)?
Trains are regularly diverted during engineering works Byfleet-Virginia Water-Clapham Junction and there are Woking-Waterloo via Staines trains so it would to these poor eyes nonsensical if the proposed route was banned!
This shouldn't be used as a rule of thumb. Engineering works cause new routeing options to become open to passengers. NXEC diverting via Carlisle for example- A ticket from Sunderland to Edinburgh would not normally be valid via Carlisle but because of the following statement in the routeing guide it becomes a permitted route
Any through train diverted from its usual route will count as a permitted route between the stations it is normally scheduled to call at. This does not apply to additional stops on the diversionary route, unless specially advised or they are on the permitted route for the journey being made.
So just because an operator uses a route as a diversionary one does not make a ticket valid via that route when engineering work is not occuring (although in this circumstance it is).
For example; a Hereford to Bristol Parkway ticket is valid via Birmingham New Str as you could have come in on the line through Stourbridge and go out through Barnt Green. At present there are engineering works on Sundays meaning the trains leaving New Str towards Bristol travel through Stourbridge?
Does this mean that you can still use this ticket to go through Birmingham?
On Southern a Swanwick to london terminals Season is also valid via Brighton, Dorking and even Lewes and also valid to London Bridge, waterloo east canon street and charing cross.I am glad to say that in the above case I was being route-specific in relation to the question. However, I am obliged as always for the extra new information. When I had a season from Swanwick-Waterloo I went either via Southampton Central or via Havant and the Guildford Direct as the mood took me, or if I was late frove to Parkway and then went from there. On the return the trains were eventually booked to go to Guildford via Cobham, and on one occasion sent south to Eastleigh instead, and thence via Botley to Fareham. I think all three main routes were permitted (i.e. change at Fareham then via Eastleigh), plus Southern to Clapham via Hove or Arundel?
