Using Contactless/Oyster PAYG do you have to tap at interchange stations?
FGW_DID
23 Jun 2011
81E
With regards to the oyster, they won’t see much as he only touches in when he enters the underground at Mile End as after that there is no touching out
Takes the tube to Stratford. Gets off at Stratford and walks to another platform. There are no barriers or touching in. It’s all within the station itself. They then board GA or TfL train. So they didn’t enter the station but rather interchanged.
Apologies to the OP slightly on topic but this is a bit of a general question to all.
The bits I’ve bolded in the quotes, I don’t really know much about Oyster and don’t have one but I thought when you touched in, you always had to touch out, even when it’s an interchange (is that what the pink readers are for?) How does the system know how much to charge for the journey, or does the user just get whacked with whatever the daily cap charge is? :?:
29 May 2013
Derby
Of course, I'm open to being corrected if I'm wrong, but I *believe* the pink Oyster readers are for passengers making a connection on a journey that has avoided zone 1 on a journey where going through zone 1 would be the most direct route so they don't get charged the higher fare.
If you’re using PAYG and touch in but don’t touch out, you basically pay a preset maximum cash fare from the origin. It doesn’t form part of the daily cap.
However, this discussion is about a staff nominee pass held on Oyster, and a bit like a season ticket it wouldn’t matter if he didn’t touch out.
Touching a pink reader is always optional, and they mostly exist to prove you took a cheaper route.
FGW_DID
23 Jun 2011
81E
Ah, I see, of course that makes perfect sense. I had a brain fart and was under the impression that the Oyster and the nominee pass were two separate items. :oops::oops:
