Virgin Restricting Access to Cycle Area on Pendolinos
DynamicSpirit
12 Apr 2012
SE London
I took my bicycle from Lancaster to Euston today, and sat in one of the usual 'Reserved - Cyclist' seats right next to the door to the cycle compartment.
To my astonishment, when the train was approaching Euston and I stood up to go sort out my cycle for getting off, I found there was no way to get back into the cycle storage area: The door from the passenger compartment to the cycle area simply didn't have the usual passenger-operable button to open it. This meant that, despite sitting right next to the cycle compartment, I had to walk down the length of coach A to the passenger door, and then back along the platform, with my rucksack and two very heavy panniers, to wait for the conductor to let me in. I asked the conductor about this, and she said that Virgin were progressively removing the button that currently gives access to the cycle storage area from all their trains.
Why???? This seems an extraordinarily bad thing to do, which will seriously inconvenience cyclist-passengers, and has the potential to delay trains too:
  • Unloading cycles will now take longer because you can't get to the cycle to prepare it for unloading until the train is in the station and someone has let you back on it (this is what could delay trains).
  • Anyone in coach A has much further to walk to get to their cycle.
  • It becomes impossible to get to your cycle en route (for example to retrieve anything you've left with it, or to check it's OK).
  • If you have heavy panniers and rucksack (as I did today) you may need to carry them separately from the cycle area to the passenger compartment after loading your cycle. This leaves a risk that the door could close while you're in the middle of retrieving your bags - and then you're basically screwed because you can't open it again - you'd have to go and find the conductor before you can get all your bags.
Is there any sensible reason to justify this?
DynamicSpirit
12 Apr 2012
SE London
And to add... it also seems incredibly bad for safety: It means that, if there's a fire or some other danger in coach A, then any passengers sitting between the fire (or whatever) and the door to the cycle area would be completely trapped, with the only exit from their seats blocked.
NoOnesFool
26 Aug 2018
If it's a similar set up to Meridians, this will be the crumple zone when forming the leading coach, meaning passengers are not allowed to travel in this compartment.
ic31420
23 Aug 2017
WHAT? My bike is in the crumple zone...! Put the bikes in the safe cell and the unwashed in the crumple zone!!!
Seriously though, if that's the case why has it been okay up to now?
There is an emergency release.
ashkeba
13 May 2019
I hope they're ready for it to be operated incorrectly lots more, then!
This seems a bit of a backwards step that must increase dwell times every station where a bike gets off, surely?
DynamicSpirit
12 Apr 2012
SE London
It’s to restrict access to the drivers cab I would imagine.
I would imagine that can be much better done by having a non-passenger-operable door at the entrance to the driver's cab itself. And I'd have assumed that already exists (though I've never looked that closely).
There is a bit of an issue on Pendolinos with people ending up "stuck" in the cycle area with bike when staff forget to let them out, as the cycle area has no passenger door controls. I do wonder if this is intended to "force" them out onto the platform, making it visible to the guard and preventing this issue, rather than specifically to keep people out of that area (as there's a secure door into the cab itself anyway, and this door is not particularly secure even with the mod).
ricoblade
28 Sep 2015
From my experience, on both LNER and Hull Trains there is no access from the passenger carriage to the cycle store.
ashkeba
13 May 2019
Neither of those operate Pendolinos and there is definitely access on LNER's Azumas because it's between carriages. Did 125s/HST sets ever have access to the store? Not adding it would be less annoying than removing a facility that was already there.
I realise class 180 Adelantes currently on Hull Trains don't, but that's just yet another reason why they're widely hated (and a relatively minor one compared to the reputation for fires...)
ashkeba
13 May 2019
Would anyone want to get off the train in that situation and risk your vehicle for onward transport leaving without you? This seems a particularly poor solution to what sounds like a problem of the train crew not opening the storage doors at certain stations which I think on Pendolinos should have all been booked in advance.
I know you all hate this sort of comment but that has never yet happened to me on Belgian trains where the low-level door needs to be opened with a key to let bikes disembark - the train crew note the destination on your ticket and return in good time. They cannott look at the bike tickets because Belgian bike tickets are day tickets not journey reservations (there are plenty of spaces, unlike the UK or the Netherlands). But I have not yet used a British train with a closed cycle store and I am glad they seem to be a rare thing.
DynamicSpirit
12 Apr 2012
SE London
I agree that can be a potential problem - as with the current situation you are completely dependent on the conductor having remembered and made arrangements to let you off. However, wouldn't a better solution to that be to add a button to the cycle door on the inside, so cyclists can let themselves off the train. That would have the added benefit that staff wouldn't be tied up letting cyclists off, although it would have the disadvantage that cyclists may be more worried about their bike being stolen (Still I would imagine that's still a very small risk).
jfowkes
20 Jul 2017
I agree that can be a potential problem - as with the current situation you are completely dependent on the conductor having remembered and made arrangements to let you off. However, wouldn't a better solution to that be to add a button to the cycle door on the inside, so cyclists can let themselves off the train. That would have the added benefit that staff wouldn't be tied up letting cyclists off, although it would have the disadvantage that cyclists may be more worried about their bike being stolen.
Yeah, cyclists can take care of ourselves. We don't want to take up crew member's time or increase platform dwell time. Just give us the means to secure our bike and get it on/off the train easily (without us or it being trapped or left behind) and we won't be any trouble!
6Gman
1 May 2012
My guess would be security.
pt_mad
26 Sep 2011
Is it the case there is no button for passengers to get through from the bike storage to the passenger accommodation? I've seen people let on and the door closed, so presumably they must be able to get through the door to the seating?
There is, but it's not easy to get a bike off that way.
xc170
9 Feb 2008
This does sound like one of those rules Virgin love to come up with.
tiptoptaff
15 Feb 2013
Unlikely, as they're either stored in the power cars, so no public access, and the van area is accessed through the guard's office.
It's a fuss over nothing, really, it is. People have managed fine leaving their bikes in a TGS for 40years
RealTrains07
28 Feb 2019
The only way into an HST store was by opening the outside door from the platform so riders would only be able to get access to their bikes after they leave the train
Nagora
17 Oct 2018
Well,unless they rode with their bikes. The 125 van used to be a popular option on some routes (SWT? It was a good while ago); I didn't have a bike and I enjoyed riding in the van in hot weather with the window open.
pdeaves
14 Sep 2014
Gateway to the South West
True. People have also managed perfectly well with slam doors and all sorts of other things that we don't want or need to go back to. The point is not that a certain facility is the way it is, it's that it has been changed from something better to something worse.
EE Andy b1
12 Dec 2013
CLC
Someone have a word with First Trenitalia and ask them nicely that when they re-furbish the Pendolino fleet to stick a bike rack somewhere in the middle of the train for around six bikes, with full access by the passengers.
DynamicSpirit
12 Apr 2012
SE London
Not quite sure what TGS means. But I wouldn't say it's 'a fuss over nothing'. For me personally, I'd say it's sufficiently awkward to make me think twice about using Virgin again when I need to take my bicycle. So LNR and TPE may find they get a bit more custom from me instead.
43096
23 Nov 2015
TGS - Trailer Guard Standard. Vehicle in an HST set that has the van area at one end.
Nagora
17 Oct 2018
When did SWT ever operate HSTs ?
I know. I was wondering that too but I've not lived in many places in England other than Newcastle (where I didn't travel by train much aside from the Metro) and Woking where I did commute for a few years and I know that I did ride in the van at least a dozen times - it wasn't some weird one-off. I'm in Swindon now but even before the 800s came in I'd always had a seat. So I'm assuming it was Woking and SWT.
