coppercapped
Clarence Yard, in another thread, has clearly and frequently stated, that ALL the Class 80X trains have the same size fuel tank. Fuel consumption tests made in 2017 showed the need for the larger tank. Only the first two or three 800s were delivered with the smaller tank and even these have now been changed.The 800s and 802s are the exact same train, the only difference between them is a larger fuel tank, and a software enhancement to use a larger power output from the engines..
As you say, the engine settings are software controlled and in the case of the IEP trains tries to maximise reliability and engine life by keeping the power output as low as possible.
The other difference between the classes is that the 802s have larger rheostatic braking resistors on the roofs.
