VWC off peak return - outward break of journey
Phil from Mon
28 Nov 2014
Beaumaris, Ynys Môn
Hi guys
I need to travel Bangor - Penrith next month for a meeting, but have another in Oxenholme on the way. Can I break an off-peak return Bangor to Penrith at Oxenholme, or should I travel Bangor - Oxenholme and rebook? Does a senior railcard make any difference? Many thanks.
mikeg
20 Apr 2010
Selby
No, as long as you stay on a permitted route from Bangor to Penrith you will be fine.
Merseysider
Fares Advisor
22 Jan 2014
If you're getting it reimbursed I suppose it won't matter, but if you're not then you may wish to consider buying two tickets rather than one, or 'rebooking' if you will.
Bangor -> Wigan is £44.10 and allows any train, but no break of journey on this bit.
Wigan -> Penrith is £33.10 and allows any train, including break of journey at Oxenholme.
Total is £77.20 and you must travel on a train calling at Wigan, which they all do.
You could also do the same thing at Liverpool if you wished, but it would be a slower journey as you'd have to change at Lime Street and then Wigan.
Bangor -> Liverpool is £30.60 and allows any train, but no break of journey on this bit.
Liverpool -> Penrith is £41.10 and allows any train, including break of journey at Oxenholme.
Total is £71.70.
