Wales and West services from Waterloo
Colin1501
10 Apr 2019
Going through some of my old photographs, I found one of a Wales and West Class 158 heading west along the SW main line near Basingstoke on 5th April 2000. My caption says that it is the 15.17 Wales and West service from Waterloo to Manchester Piccadilly and Pembroke Dock. However, I'm now wondering how a single unit could have served both destinations. Did it attach to another unit somewhere en route, and then divide again further on? Did it serve one destination first, and then the second one - although either option would have been a bit of a circuitous journey, especially Waterloo-Manchester-Pembroke?! Or did I simply get it wrong?
If anyone remembers or has access to the timetable at the time, I'd be grateful to know.
Colin
Ash Bridge
17 Mar 2014
Stockport
Colin
I have a copy of the National Rail timetable dated 28th May - 20th September 2000 and according to this you are quite correct about the 15:17 Wales & West service from Waterloo to Manchester Piccadilly & Pembroke Dock. It appears that it combined with a second W&W 158 from Portsmouth Harbour upon arrival at Bristol TM going as far as Newport from what I can tell, where the two units then split and went their separate ways, hope this helps...
Colin1501
10 Apr 2019
Brilliant - thanks very much. Glad to know I hadn't dreamt it! I wonder how many other examples there are of portion working where two units join at one point of the journey and then detach later on.
Bringback309s
22 Aug 2013
I once travelled on a regular very late service from Newport (I believe, or Cardiff) into Paddington which was a RR class 158. It was about 1996. Apparently a pacer once stepped in for it!
MatthewRead
21 Nov 2014
West london
I've never seen 158's at Paddington once saw one at Goring & Streatley in 2001.
Cowley
15 Apr 2016
Devon
I think these services have popped up on here before a couple of times.
What sort of journey times would they have taken end to end Mr B?
Ash Bridge
17 Mar 2014
Stockport
The 15:17 off Waterloo arrived into Pembroke Dock at 22:12 with the Manchester portion reaching Stockport & Piccadilly at 21:24 & 21:34 respectively.
pdeaves
14 Sep 2014
Gateway to the South West
thenorthern said:
Here is the timetable from 2003, it seems back then there was a London Waterloo to Manchester Piccadilly via Shrewsbury, Cwmbran and Bristol I never knew that.
I think the current SWR Waterloo-Bristol service is a remnant of this service.
Cowley
15 Apr 2016
Devon
Interesting thank you.
