Weird Places for Services to Terminate
PointA Rail
31 Oct 2024
Two interesting ones that aren't necessarily relevant but I think are still worth a mention definitely caught my eye at the time of noticing them.
[1] A late night service on 16 July 2022 saw Class 155341 run under a single headcode 2R28 from Bridlington to Leeds via Harrogate, which stood in York for around 30 mins with passengers onboard before continuing onwards. Nowadays, the service seems to have been split in two, with the latter half becoming 2C75 and the standing time increased by another 10 mins. The images attached show the unit running the service paused in Platform 5 at York, and an image of the cab GSMR displaying 2R28.
[2] The other service is not a passenger service but a very circuitous early morning ECS move involving 5K99. Starting it’s day at 04:15 by exiting from the northern end of Hornsey Depot, it reverses and runs down to Highbury Vale Junction where it then reverses again towards Bowes Park Reverse Siding (guess what it does there :lol:), before then making its way to Finsbury Park and operating the Staff only train 2K99, arriving into Moorgate for 05:29. After Moorgate it then becomes the first service from Moorgate to Stevenage under 2F00. There’s likely reasoning for this, likely to do with how the unit from the previous day's diagram was stabled, but it feels like a hell of a routing for the driver regardless. Probably the most walking a driver has to do under one headcode!
https://www.realtimetrains.co.uk/service/gb-nr:W24558/2025-05-14/detailed 5K99-1
https://www.realtimetrains.co.uk/service/gb-nr:W24559/2025-05-14/detailed 5K99-2
https://www.realtimetrains.co.uk/service/gb-nr:W23868/2025-05-14/detailed 2K99
mathstrains19
14 Apr 2024
Cambridgeshire
I wonder if that one is more for route knowledge to Highbury Vale Junction to allow impromptu turning there when required?
318266
30 Sep 2017
S&W of Alexander Dennis, N&E of Wrightbus
Does Anderston count?
Also think the old Baldock Terminators are a bit random
Carstairs in and of itself is a bit of an unusual location to terminate, being essentially part of Carstairs Junction which is notable for being in the middle of nowhere. Excluding the sleeper splitting, only a couple Argyle Line services terminate there, on peak runs. The rest of the time, it is served by Glasgow Central - Edinburgh via Motherwell and Carstairs services, usually then running non-stop to/from Haymarket.
dtin
3 Nov 2019
Bristol
I would've also thought Anderston is an odd place to start/terminate as well, especially as most of those services go to/from Dalmuir/Milngavie.
D6130
12 Jan 2021
West Yorkshire/Tuscany
In the early days of the reopened Argyle Line, the Monday to Friday peak hour Carstairs and Lanark semi-fasts terminated at Anderston so that they could serve the main city centre stations and then turn round in the reversing slding at Finnieston (now Exhibition Centre).
GordonT
26 May 2018
Bellgrove and High Street have also been peak time termini at least in some past years.
A S Leib
9 Sep 2018
Looking at signal.eu.org I suspect Yoker depot is the explanation, but otherwise having six trains per day (starting from Carstairs, two from Edinburgh, two from Larkhall and Springburn) terminating at Garscadden rather than Dalmuir feels slightly odd.
D6130
12 Jan 2021
Indeed....and after Bridgeton Central closed to passengers with the opening of the Argyle Line in 1979, it remained open as a train crew and carriage servicing depot for several years. During that period services which had formerly started and terminated at Bridgeton now did so at High Street and ran empty stock between there and Bridgeton.
Yoker depot is indeed the explanation.
PointA Rail
31 Oct 2024
You make a good point. The thing is there are several instances of reversing at Highbury Vale after the evening peak. I believe they were brought in very recently, which would now render that purpose obsolite, but I'm not too sure. I just remember the evening Loop ECS moves heading direct from Hertford North or Gordon Hill to Hornsey Depot. In the past though, you might be right, but there might be evidence to suggest that the train used to turn around at Harringay Rev. Siding instead.
Side note, the limited weekday peak time Gordon Hill services aren't a bad edition to the list of unusual terminating points.
Magdalia
1 Jan 2022
The Fens
There is a fairly long history of using Highbury Vale as a reversing point for ECS moves. When the Ashburton Grove stadium first opened there were additional trains to/from Finsbury Park on matchdays that used Highbury Vale for reversal if there was insufficient platform capacity at Kings Cross (in those days Moorgate was closed at weekends and after 2200 on weekdays). Highbury Vale also had a cameo role in the great Finsbury Park fiasco of Christmas 2014.
Going back to before electrification the GN suburban service had lots of different terminating points, including Finsbury Park, Cuffley, New Barnet, Potters Bar, Hatfield, Hitchin and Baldock.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
It's simply a convenient place to start additional peak hour trains from the Glasgow Central Low Level line towards Lanarkshire, reversing as @D6130 says at Exhibition Centre Siding; If that had a platform the trains could start there!
class ep-09
5 Sep 2013
Not sure if it is on topic but sometimes during engineering works on South Cotswold Line ( Stroud Valley) Down trains towards Gloucester from direction of Swindon terminate at Stroud going “wrong road “ Single Line Working with Pilot all the way from Kemble Up Platform (which in itself is bi-directional).
