DerekC
Aircraft have been able to make approaches to runways in zero visibility, navigating by sole reference to GPS signals, for many decades now. The suggestion that GPS isn't reliable enough to be used for safety critical applications is absolute bunkum. Yes, the kind of GPS you get on a smartphone isn't good enough. But if you pay the right people enough money you can get kit that can be guaranteed to be sufficiently accurate and failsafe.
The simple truth of the matter is that not enough people have died, or will die, over the railway's stubbornness in this regard, for it to have become a priority.
Yes, there are places where GPS signals from satellites won't work. But it is no different to the implementation of GSM-R - where there is a will, there is a way.
The idea that aircraft fly around using GPS only is simply not true. Here's a link to an easy-to follow and up to date explanation of the systems used by commercial aircraft:
https://www.flightdeckfriend.com/2020/04/20/how-do-commercial-aircraft-navigate/
An extract from the article is as follows:
Commercial aircraft utilise a number of navigation systems to help guide the flight from point A to B. The systems are of varying accuracy, with GPS being the most accurate method (a bit like the Sat Nav in your car) but there are a number of other systems such as an internal navigation system which doesn’t use any external reference as well as some radio beacon receivers which are used for particular phases of flight such as the departure or arrival / approach segments.
GPS – Global Positioning System
This is one of the primary navigation sources and the aircraft is continuously attempting to monitor its GPS position. This is also typically the most accurate navigation system on most modern commercial aircraft, in some circumstances allowing the aircraft to perform manoeuvres down to an accuracy of 0.1 Nautical Miles.
However, due to its reliability, it can only be used for primary navigation during certain segments of the flight. To use GPS as the primary navigation reference for the Departure (Standard Instrument Departure or SID), or Arrival (Standard Terminal Arrival or STAR) or Approach (RNAV or RNP/GPS/GNSS Approach) specific approval for both the aircraft and airline is required.
GPS is susceptible to a number of limitations. First of all, there are GPS black spots where there may not be enough satellites in range to obtain a position. Clearly this is not acceptable if operating at the aircraft with sole reference to GPS when close to the ground. GPS is also subject to jamming or interruption due to a number of reasons, such as military conflict.
Should the aircraft GPS receivers fail, or if the GPS system/satellites were to go offline, the aircraft has suitable redundancy in-place to ensure it can still navigate to an acceptable level of accuracy.
IRS – Inertial Reference System (IRS)
The IRS (older versions are referred to as Inertial Navigation Systems) is a self contained system that is able to track the aircraft position with no external reference. It uses a combination of accelerometers and gyroscopes to calculate any movement and acceleration of the aircraft across any of its three axis.
Radio Aids
Radio beacons, normally located on land, send out radio beams which tell us the aircraft’s range and direction from that radio aid. This allows the aircraft’s computer systems to calculate the aircraft’s location. The more radio signals that can be detect, the more accurate the estimated position is.
These radio aids are typically referred to as Very High Frequency Omni-Directional Radio Range (VOR) with associated Distance Measuring Equipment (DME). Others include a Non-Directional Beacon (NDB) bit this purely provides a pointer towards the beacon rather than any direct radial or distance information.
Instrument Landing Systems (ILS) are used to help guide the aircraft into land.
