What happens to you (as a train driver) in this situation
CatchMeIfUCan
22 Nov 2017
Just wondering...
As a train driver, if you was due to work over the weekend but your toc had planned engineering works throughout the weekend. What happens in term of work? Paid and Laid off?
Minilad
26 Feb 2011
Anywhere B link goes
Well where I am your job would either be amended to take the works into account or the job would be cancelled and you would revert to spare at the same times of the original diagram.
You wouldn't be laid off.
10 Mar 2013
Just wondering...
'laid off' has a quite specific meaning in such discussions
as the other reply said the TOC would have three Options
1. a revised rota to fit services that were operating
2. ask you to report to your usual ( or agreed alternative) place of work to be a 'spare' / 'standby' or carry out other reasonable management requests ( i suspect that Conductors/ guards / train managers / RPI or other customer services staff might be asked to reinforce station staff if there was loads of disruption due to the works )
3. stand you down to a on call status but still pay you
theironroad
21 Nov 2014
Generally means far too much time in taxis, coaches or buses to get the driver to a point where they can work trains.
theironroad
21 Nov 2014
Well option 1 is the only one my TOC does.
Just wondering...
On LU the duties will be rewritten. This may result in people travelling (in work time) to and from another location on their line to carry out work, or sitting spare. If spare, again they may be instructed to travel to another location so that they may be more useful, or they may simply sit spare at their home depot - in which case it's an opportunity for management to carry out P&D interviews and the like (although bear in mind on a weekend there won't be so many managers about!). Drivers may also be granted odd leave days.
father_jack
26 Jan 2010
Where Sunday is not part of the working week, you can be told you're "not required" to do your "booked" (or whatever the terminology used locally is) Sunday. Exactly why nobody gets into bother for not doing the Sunday when they choose, it's non pensionable/contractual.
Panupreset
8 May 2015
At my TOC and my depot it would be:
1. Revert to spare (least likely)
2. Diagram modified (start time altered by up to 60 mins and diagram extended by up to 60 mins).
3. Diagram cancelled and given another diagram provided it fits the parameters in 2 above.
My TOC are quite happy to put you in a taxi for an hour each way to go do something else somewhere else.
Another TOC local to mine have allowed drivers to stay at home during engineering works at the weekend as their whole route has been affected.
coxxy
16 Aug 2013
Generally job cancelled or STP so that youbhave different work... usually works out that a nice job turns in to a very bad job at our TOC
jamesst
4 May 2011
Merseyside
Nothing good at our depot. Any decent jobs usually get extended to cover taxis to where ever trains are operating to/from
jopsuk
13 May 2008
Just wondering...
surely for (long term) planned enginerring works the rostering takes care of this anyway?
Michael.Y
14 Oct 2011
Just wondering...
I would point out that a TOC doesn't do engineering, Network Rail does but.....
On the last load of engineering work in the Severn Tunnel I worked half the booked turn (the train journey was extended by an hour so I was relieved half way) and then was taxiid back to the depot after ending up on the other side of the water.
PennineSuperb
8 Jun 2018
I'm a Guard, however at our place they generally give us work that is Diverted and STP (Short Term Planning.)
However, recently with the Liverpool Blockade and all trains terminating at Manchester Victoria they have been giving us STP diagrams with a longer break at Manchester Victoria.
For example,
Last week I booked on at York 0943.
1P65 - 1004 York - 1058 Middlesbrough
5P74 - 1100 Middlesbrough - 1155 Middlesbrough
1P74 - 1157 - Middlesbrough - 1409 Manchester Victoria
Break 35
Prepare Train
1E47 - 1832 - Manchester Victoria - 1943 York
Book off at 1953
Nearly every job has been SPT similar to this with just the Liverpool portion removed, giving a large break and a waste of resource.
