What has happened to the Transpennine Express services from Scarborough?
Class08Shunter
18 Aug 2022
North Yorkshire
What has happened to Transpennine Express services from Scarborough? Most of them terminate at York. What happened to the Scarborough-Liverpool Lime Street service? Has it been terminated? Has the Scarborough-Manchester Airport service been terminated as well? Will there be more long distance services in the future?
D6975
26 Nov 2009
Bristol
Try doing a quick search first - most subjects of note already have a thread.
800001
24 Oct 2015
Due to the continued issues that TPE have trying to resource crews to cover their service, it is easier for them to operate a Scarborough to York shuttle.
It operates more reliably than if it had to operate across the Pennines, as if it continues to Manchester or Liverpool it needs multiple crews to operate, if any one of those is missing, 9 times out of 10 the service is cancelled through out.
Metroman62
4 Feb 2011
Amersham
I much prefer a reliable shuttle to York than an unreliable through service. I often travel to and from Leeds. If I can get to York I can get to Leeds. If a through train is cancelled I have an hours wait
Llandudno
25 Dec 2014
Might be best if Scarborough was served by a shuttle service to York, but every 30 minutes on a clock face frequency 0600-2330
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
I’m not sure where you’ve been if you’re only just noticing this now. It’s been this way for the best part of three years.
class 9
18 Nov 2010
They seem now to be running through to/from Manchester Piccadilly every 2 hours.
3RDGEN
6 Mar 2023
Hull
The Scarborough and Hull services were swapped last December so Scarborough now gets a service to Manchester Picc and Hull to Liverpool, why this was done I have no idea.
On paper the current weekday timetable is Scarborough to York hourly with ever other one going to Manc Picc, alternating with a two hourly Newcastle - Manc Picc service. It appears this will continue to be the case in the new May timetable.
In the real world TPE run whatever they like, however they like.
nr758123
3 Jun 2014
West Yorkshire
The impetus behind this idea came from political and business interests in Hull, who wanted both faster services to Manchester and through services to Liverpool.
That's certainly the impression they manage, however unintentionally, to convey to their passengers.
Class08Shunter
18 Aug 2022
North Yorkshire
Problem is that their connecting services leaves a few minutes before the train you're on arrives.
Class08Shunter
18 Aug 2022
North Yorkshire
What happened to the services from Scarborough to Manchester Airport? If there are services from Manchester Airport to Scarborough every monday and saturday, why wouldn't there be services from Scarborough to Manchester Airport?
There are only a handful of direct services at the fringes of the day. Effectively they are an extension of what would otherwise be one of the overnight/late/early York <-> Manchester Airport workings, used to rotate stock and keep diversionary route knowledge up.
