Route(s) affected
All routes through Barnham
Description
The police dealing with an incident near the railway at Barnham is causing disruption to journeys through the station.
Services may be cancelled, delayed by up to 60 minutes or revised.
We anticipate disruption will continue until 12:00.
Customer Advice
Due to the police dealing with an incident near the railway in the Barnham area, fewer trains will run on all Southern routes between Brighton, Littlehampton, Portsmouth, and Southampton Central.
Your journey will take up to 60 minutes longer than usual, and you may need to use an alternative route to reach your destination.
Southern services which normally split at Horsham and run direct to Bognor Regis have been cancelled.
Due to this Southern services which normally run from London Victoria to Bognor Regis will cover the stations between Horsham and Bognor Regis.
Southern services which run direct from Bognor Regis to Littlehampton & services which run direct between Littlehampton and Portsmouth and Southsea have been cancelled.
A special service has started to run between Bognor Regis and Chichester.
You can use your ticket to travel at no extra cost on:
- Southern and Thameslink services on any reasonable route
- South Western Railway services between Portsmouth/Southampton/Havant and London Waterloo
- Great Western Railway services between Southampton and Portsmouth and also Gatwick Airport via Reading to assist those with onward journeys
- London Underground between London Terminals – for London Waterloo and connections via South Western Railway services.
- Stagecoach Buses route 700, which runs between Brighton and Littlehampton, and between Littlehampton and Portsmouth and 500 which runs between Littlehampton, Barnham, and Chichester
- Brighton & Hove Buses on all routes for stations between Brighton and Shoreham-by-Sea
Click
here for help with Stagecoach timetables and
here for help with Brighton & Hove buses. For help planning your journey, you can find alternative route maps on the website
here
Before travelling, please check journey planners and station information boards, and allow extra time to reach your destination.
Check the live map
here to see if your journey has been affected.
Can you tell me more about the incident?
The police have been dealing with an incident in the Barnham area which had caused structural damage to a train crew depot building. This had to be evacuated for safety.
A structural engineer from the local council has attended and deemed safe following an inspection.
Barnham train crew depot is a major personnel and equipment hub for train drivers and on-train staff. A large number of train crew have been unable to start their duties this morning, which will severely affect services throughout the west coast area into the rest of the day.
Staff are now working hard to return services to their booked timetables but due to the earlier disruption and displacement of crew this will take some time.
Check before you travel:
You can check your journey using the National Rail Enquiries real-time
Journey Planner
Compensation:
You may be entitled to
compensation if you experience a delay in completing your journey today. Please keep your train ticket and make a note of your journey, as both will be required to support any claim.
