Shouldn't this be more of what will happen to the Class 91's once IEP replaces them.
The Midland Mainline could go down the high speed EMU route which was preferred by the EMT MD from an Interview.
good I like the class 90
Surely one class 90 is much the same as any other?
No two trains are the same
Won't EMT be gone by the time the MML is wired, a new franchise may have different ideas.
I don't think the 91s will be short of homes. Open Access I think will snap them up. They may things like haul them away from the wires? But lets say Hull - Selby - Doncaster gets wired - Hull trains may want them. Likewise (poacher rail may decide to start a London - Leeds / Edinburgh service to compete with east coast). Depends on what the regulators view is of such a service by 2020.
This is very true, but we must look at current train times and knowing the Class 91's are extremely high geared, they are not suitable for replacing the Class 90's with AGA. I wouldn't be surprised if the Meridian fleet has the advantage on acceleration. I don't deny they would be excellent in terms of luggage space, comfort and facilities onboard but I feel the 91's gearing will let them down. And in this day in age I cannot see the train planners recasting the entire timetable for slower acceleration services when they try to squeeze blood from a stone in regards to train paths.
Greater Anglia post 2020 has the possibility for High Speed Intercity style EMU's for London -Norwich. Its been said before and never caused much of a stink when it was suggested. Personally I believe this is a good thing, a 444 style unit with 110mph max speed for a 2 hour journey based around 5 car sets, off peak non busy services single set & doubled for morning/evening peaks.
Hull Trains have said they will order brand new 125mph EMU's. Grand Central have committed to a Class 180 fleet with their extended operating licence once FGW release Class 180's when IEP is fully in service.
Indeed, its not like theres any particular member of the class which is unique (there's no 87101 and even that wasn't noticeably different)
why don't trains have a gearbox with which one can change gear like that of cars?
Somebody much more technically minded will no doubt answer this properly, but the simple answer is that an electric motor (eg in a train) works in a very different way to the piston engine in a car; the power output of a train engine is also so much more than a car engine that having some form of gear change mechanism would create a massive weak link in the transmission (imagine the clutch!). In a different vein, piston engines in aeroplanes and boats don't have the ability to change gear either, but that is because they are pulling/pushing against a fluid rather than a solid so it doesn't matter a great deal. As it happens, most aircraft propellers these days are variable pitch which allows the pilot to get the best from the engine at different airspeeds - in effect, changing gear - without varying the engine speed.
I may also be missing something, but trains have had "re-gearing in the past".
150002 became 154002 (with up gearing to 90mph) correct
Didn't some of the 90's get down geared to 75mph for better traction effort on larger trains (someone will need to correct me here as I could be wrong) not that I am aware of, only the top speed was limited, the gearing remained the same.
I am sure some of the 86s were "re-geared" for freight working.correct, but only 86501 was physically altered
Alot of the 90's have had too short lives. Probably safe to say alot of those stored at Crewe Electric will never move again under their own power.
Well never say never... 90037 is about to return to traffic, from being stored in 2006 I think it was
Secondly, why can one not re-gear a train to alter its acceleration profile, and also why don't trains have a gearbox with which one can change gear like that of cars?
