What should be done with Heathrow Express once Old Oak Common opens? And how could the paths be best used?
Going to Staines doesn’t add that much IMO.
Yes, Staines isn't easy to get at and doesn't have that great a 'catchment' area for quick and easy connections.
I don’t see how they can expand Heathrow without HSL to Woking. The M25 just can’t take it.
I don't see Heathrow paying for more rail links. The current work at Wisley on the M25 / A3 junction buys a bit of time for the M25, and some work would need to take place where the 'tunnel' is expected to be built but no railway can realistically displace the traffic given the disparate nature of the various journeys being undertaken.
BranstonJnc
4 Apr 2025
Castle Gresley
Has anyone yet suggested that by opening the Heathrow Western Rail Link, you could potentially 'loop' a quarter-hourly service off the main line at Heathrow Airport Jn, make some sensibly-timed station calls (3 minutes a piece), and then re-join at the west side on the reliefs to continue to somewhere like Didcot Parkway or Newbury? Perfect use of the 387 fleet, probably able to run some 12 cars.
Just to really throw a hand grenade, could you then release some relief line capacity accordingly, and have a half-hourly 'Crossrail Express', with a simultaneously-timed move at Portobello / Ladbroke Grove straight onto the main lines and run it non-stop to somewhere like Maidenhead?
Yes, it has been suggested, but do people from the stations at which the Didcot Parkway and Newbury services stop want a 15 minute detour on their journey to London? I don't think 12 car 387s currently fit at Heathrow.
Loop services are notoriously difficult to path in amongst services taking the direct route, and no one is seemingly interested in paying for western access.
Simultaneously timed doesn't mean simultaneously operated, and isn't great over a flat junction immediately outside Paddington. The 345s only do 90mph.
Great theory, but operationally less than ideal.
BranstonJnc
4 Apr 2025
Castle Gresley
If you can flight the path in at the right point, one assumes it could just about sneak ahead of something that then stops at Slough? Do GWR still stop the Oxford trains there or has that died a death?
I suppose ref: Newbury and Didcot, there is not such thing as a perfect fix for anybody. But if you're coming from Pangbourne, you're probably already upset at the fact your train stops at all these extra places on the way to Paddington, so you might already jump off and get an IEP. Same for Midgham or Aldermaston. But on the flip side, do your O-Level geography and your teacher will have said about the M4 Corridor, and the need to open up an expanded Heathrow with a western connection is key, and when a lot of the businesses are between Didcot / Newbury and Slough, you're already there as to why the balance would mean these people would need to bare an inconvenience. The same folk, if travelling for leisure, may be equally happy to be using a train direct to Heathrow in future.
You don't want to divert IEPs down into the hole, but 387s are perfectly sensible. Add in Oxford electrification and you're laughing as the stopping 387s can then continue beyond Didcot.
This is essentially one option of what was proposed, albeit with 8 cars, as 12 don’t fit.
But the western link doesn‘t release Relief line (or Main line) capacity east of Heathrow.
BranstonJnc
4 Apr 2025
Castle Gresley
Technically it could release main line capacity east of Airport Jn / Stockley Jn. If we assume the current Didcot services go to Dolphin Jn (?) and cross over, or somewhere along there, they are trains (as are the through Newbury electrics) that currently run in addition to the Heathrow Express. If you are using the Heathrow Express paths, which are 4tph, and then putting them back onto the relief lines to continue to Newbury and Didcot then you have actually released paths at off-peak and peak times out of Paddington for more Intercity services.
Add in the fact that if you could be smart with the building of the Western link, and all through traffic could use one platform at T5, allowing Crossrail to increase to 4tph to Heathrow. This will be critical when it expands. The extra half-hourly Reading at high peak could be run round into Heathrow T5. It wouldn't really adversely impact much other than West Drayton, and you could probably find the necessary space for a further pair of slots per hour to be a Drayton terminator, once Old Oak opens.
Having now released more main line capacity, you can now slot in a half-hourly additional capacity buster service (like a 12 car 387 to Swindon, or Reading, or Didcot) which stops at Slough, Maidenhead and then Reading if desired, as the commuter layout and acceleration will allow them to probably flight in behind something in a good gap. This assumes your 1Dxx or 1Kxx paths have been binned and are now operating in the HEX departure times.
So you end up like this:
- xx:00 Penzance - fast from Reading to Exeter St Davids. Overtakes xx:42 Newbury via Heathrow.
- xx:03 Bristol Flyer - fast from Reading to Bristol Parwkway, possibly beyond Temple Meads to Weston or Taunton.
- xx:06 Bristol via Bath - Reading, Didcot Parkway, Swindon, Chippenham, Bath, Bristol.
- xx:09 Oxford / Hereford / Worcester, fast to Reading. Possible Didcot Parkway if required.
- xx:12 Newbury 387 - Heathrow Central, Terminal 5, (relief lines) Slough, Twyford, Reading, stations beyond.
- xx:15 Swansea - fast from Reading to Swindon.
- xx:18 Supplementary Berks & Hants IEP - e.g. Westbury / Frome / Bristol via Trowbridge / Exeter stopper / Paignton. Possible stop at Slough or Maidenhead given size of gap.
- xx:21 Gap - option to flight in an express Crossrail path at Ladbroke Grove in this six minute space, fast to somewhere like Slough (crossover at Dolphin) or even at Stockley Bridge.
- xx:24 Gap
- xx:27 Didcot Parkway / Oxford (if electrified) 387 - Heathrow Central, Terminal 5, (relief lines) Slough, Maidenhead, Reading, stations beyond.
- xx:30 Bristol Flyer - fast from Reading to Bristol Parwkway, possibly beyond Temple Meads to Weston or Taunton.
- xx:33 Plymouth / Penzance / Paignton - Reading and then key stops such as Westbury. Overtakes xx:12 Newbury via Heathrow.
- xx:36 Bristol via Bath - Reading, Didcot Parkway, Swindon, Chippenham, Bath, Bristol.
- xx:39 Oxford / Hereford / Worcester, fast to Reading. Possible Didcot Parkway if required.
- xx:42 Newbury 387 - Heathrow Central, Terminal 5, (relief lines) Slough, Twyford, Reading, stations beyond.
- xx:45 Swansea - fast from Reading to Swindon.
- xx:48 Cheltenham Spa - including Didcot Parkway. Possible stop at Slough or Maidenhead given size of gap.
- xx:51 Gap - option to flight in an express Crossrail path at Ladbroke Grove in this six minute space, fast to somewhere like Slough (crossover at Dolphin) or even at Stockley Bridge.
- xx:54 Gap
- xx:57 Didcot Parkway / Oxford (if electrified) 387 - Heathrow Central, Terminal 5, (relief lines) Slough, Maidenhead, Reading, stations beyond.
MatthewHutton
17 Aug 2024
Oxford
As much as I have been vocally anti OOC, in Europe it is the norm on IC services to have Berlin Hbf, Berlin Ost, Dresden for example, same for Zurich Oerlikon, Hbf, Bern non-stop where the main city has two calls and then non-stop to the other city but here IC services double as regional services in a lot of places and it's not practical in terms of capacity to slow them down when you only need to go five minutes in and back out again. They also crowd space for passengers going much longer distances.
And Asia.
Even the fastest express trains stop at:
Shingawa/Shin Yokohama/Kyoto/Shin Kobe/Ueno/Omiya/Kokura in Japan.
And the same applies to Nangang/Bangqiao in Taipei.
Heathrow has pretty good road access to the West. I mean you can be at Thornhill in Oxford in an hour on the coach in most circumstances.
BranstonJnc
4 Apr 2025
Castle Gresley
And Asia.
I mean, a direct rail service is always better, especially if its relatively quick to Reading. I don't think we can possibly be suggesting not building Heathrow Western Rail in order to instead stuff everyone into bloody buses.
Are we doing that? Don't passengers currently change trains at Hayes & Harlington without using buses?
One of the problems with making a case for the western access could well be that passengers already have an all-rail option.
It is one of those where the economics rely on 'new-to-rail' custom, since there are already passengers changing at Hayes & Harlington.
BranstonJnc
4 Apr 2025
Castle Gresley
So you expect folk to jump off their Intercity train at Reading, to then sit on a potentially very busy Crossrail, to get to Hayes and then change again? When they could be off at Reading, and straight onto a very specific, very well-designed (internally at least) train designed for this Airport capacity direct from Reading? Also direct from somewhere like Oxford (if wired), Didcot (possible EWR station), Newbury, and of course all the potential workers who would want to jump on it from big places like Maidenhead and Slough to go straight to work.
No, I'm saying that the base level of demand from people who live near Heathrow is satisfied by the existing arrangements, and that the demand from other users travelling from further afield is unlikely to be sufficient to pay for the enhanced infrastructure.
If it was capable of being 'self funded' I imagine western and southern access wouldn't have been shelved.
At some point, people will be able to change at Old Oak Common for Heathrow, and at present they can change at Paddington for Heathrow.
BranstonJnc
4 Apr 2025
Castle Gresley
I think we can agree to disagree on whether there would be sufficient demand. Pretty much anybody who works in infrastructure planning would say that as the airport expands, it's going to be vital, and it will be remarkably popular.
I don't doubt the demand. It is clear that there is a lot of car traffic to Heathrow, not put off by the car parking charges, and also that people are happy to book taxis to get there. The question is whether the project is self funding.
BranstonJnc
4 Apr 2025
Castle Gresley
  • The need for a western rail link to Heathrow is well acknowledged. The business, economic and environmental case for the rail link is strong – £1.5 billion of efficiency savings, £800 million of additional economic activity, 42,000 new jobs, modal shift from road to rail, one million fewer road journeys and 5,200 tonnes less CO2 released into the atmosphere.
  1. An assessment of the potential wider impacts of WRLtH services suggests a much greater need for the scheme than pure transport benefits. The improved access to Heathrow and the surrounding economic hubs will strengthen the position of the Thames Valley on the world stage: forecast increase in economic activity could generate up to £800 million in additional economic output and employ up to 42,000 new jobs.
  2. These benefits will not be limited to the Thames Valley. With almost 20% of the UK population within one interchange of Heathrow Airport, the WRLtH services will bring knock-on economic and employment benefits to areas in the West of England, South Wales, the South West and the Midlands.
  3. Conventional economic appraisal suggests benefits in excess of £1 billion over a 60-year appraisal period, the majority of which will accrue to new and existing rail passengers as a result of substantial journey time savings (Journey times from Reading will be halved; from Maidenhead and Slough they would reduce by up to 72%). The scheme will deliver high value for money as a result with a benefit-cost ratio of 3.80;
  4. Forecast of the financial viability of the scheme suggest that it will provide a profitable business for the rail franchisee, generating annual revenues of up to £70 million per annum, and returning an overall profit on total investment within nine years of opening.
  5. Improving transport links to Heathrow airport will support existing businesses in the Thames Valley, 75% of whom state proximity to Heathrow as the most important factor in their location, and will encourage more inward investment from new companies establishing in the UK for the first time, 70% of which locate within 60 minutes travelling time of Heathrow. With an economy worth nearly £30bn, an investment of £500m would help to safeguard the future of the Thames Valley, and the entire UK economy.
But no, clearly getting people to double change at Reading and Hayes is an excellent idea.
BranstonJnc
4 Apr 2025
Castle Gresley
Single change at Old Oak Common?
(Which will clearly be the next infrastructure change as it is actually being built.)
  1. Improving transport links to Heathrow airport will support existing businesses in the Thames Valley, 75% of whom state proximity to Heathrow as the most important factor in their location, and will encourage more inward investment from new companies establishing in the UK for the first time, 70% of which locate within 60 minutes travelling time of Heathrow. With an economy worth nearly £30bn, an investment of £500m would help to safeguard the future of the Thames Valley, and the entire UK economy.
Clearly it is the need of any business to specifically be within 60 minutes, so to demand they go to Old Oak and then backtrack, probably on a stopping train, is also not good enough. The details as quoted show that this link being built will have a benefit of £3.80 to every £1 spent, so is worth building on that basis alone.
The Ham
6 Jul 2012
I'm sorry? Heathrow Express to Southampton & Portsmouth? Whats the point of calling it Heathrow Express then?
From those places it would be far faster than any other current option.
Ahh yes I remember that plan (vs the triangle) - would be better.
So it would be:
Paddington - OOC - LHR 2/3 + 5 - Woking... wherever.
Indeed, the "planned" end points are Basingstoke and Guildford (2tph each).
Depends on how they operate, but having a direct access can Basingstoke, Guildford and Woking by train would make rail travel to the airport fairly attractive.
However, a lot of the distance which the trains will be traveling would be on existing tracks and will be able to pick up a lot of local travel from increasing frequency between stations.
Whilst the extra trains would mean extra maintenance, there's a lot of fixed costs with running the railways which works be split over more customers.
For example, having 5tph between Basingstoke and Farnborough rather than the current 3tph would make rail travel on that corridor much more attractive than it is currently.
Likewise having a similar frequency between Guildford and Woking would also be helpful.
That's before you consider the journey options which become much easier. For example Woking to the GWML and to Old Oak Common for HS2.
BranstonJnc
4 Apr 2025
Castle Gresley
Heathrow Southern Access requires two things, doesn't it? Woking Junction remodelling with a flyover, and a new-build section underground in bits right from Heathrow to Virginia Water, omitting Staines.
How many trains you can really think to path, if you've got freight and such too, who knows. But it would require quite a few difficult choices...
The Ham
6 Jul 2012
Woking Junction grand separation may not be needed immediately, given SWR services aren't at full pre COVID timetable. However even if it was, then Woking Junction would be useful for reliability of the network and other capacity enhancements (like Crossrail 2).
- xx:24 Gap
- xx:48 Cheltenham Spa - including Didcot Parkway. Possible stop at Slough or Mai4denhead given size of gap.
- xx:54 Gap
I'd be a bit nervous of running a flight of 8 like that.
MatthewHutton
17 Aug 2024
Oxford
OK so there are 2tph semi-fast to Maidenhead then slow to Didcot, 1.5tph towards Exeter, 2tph to Bristol, 2tph to Cardiff, 1tph to Cheltenham and 2tph to Oxford.
And the relief tracks are full with the current 4tph Elizabeth line to Maidenhead plus freight.
That is 10-11tph in total on the fast tracks and 4tph plus freight on the slow tracks.
With all that where is the capacity for extra Heathrow trains? And if there is wouldn’t you want to boost the medium/long distance routes with extra service to central London?
And if they were squeezed onto the relief lines wouldn’t they be slow?
Britain runs a very heavy service compared to our peers as it is. Japan does more - but less than what is proposed above - and with much less network complexity.
Meerkat
14 Jul 2018
The A3 junction work is for solving that junction’s significant problems. It won’t help the Heathrow section of the M25, in fact it might make it worse by taking out a previous bottleneck for those from SurRey/Hampshire.
A rail link onto the Woking lines would serve a huge number of people who would otherwise drive or get a taxi.
The Ham
6 Jul 2012
The other thing to consider is the motorways are congested now, they almost certainly couldn't cope with the extra traffic from a third runway.
As such it's not just a case of could a rail link be viable now, but what would that look like if it was taking 10% of current vehicles (due to the uplift from the extra runway, which could be as much as +33%)?
10% extra would be the equivalent of about 120 flights a day, of we assume an average of 160 people per flight (based on the most used aircraft which is the A320) that works out at an average of 500 people per hour per direction over an 18 hour day.
Over a 4tph that's 125 people per train, yes that's fairly lightly loaded train, but that's assuming 90% of new passengers travel by other modes and 100% of existing passengers carry on travelling how they currently do. It also assumes no other travel (those going to Old Oak Common or Paddington/Euston).
MatthewHutton
17 Aug 2024
Oxford
It might well be that if you tunnelled through the other side of Heathrow towards Woking that there is capacity on that side. Personally I have no idea - but to be fair given there aren’t loads of longer distance destinations it is very possible.
Railguy1
6 Apr 2016
Any plans for a third runway should really involve also building both the southern and western rail links to Heathrow in my view, which would then also support continued use of HeX.
Before commiting to the substantial sums of money required for the rebuilds needed to actually use the Southern Rail access project, how about testing if southern access is really attractive by building an urban ropeway conection from Heathrow TErminal 4 to Ashford (Surrey) station?
Theres a route over the reservoirs that doesn't overfly any residential properties with only a single angle tower. The journey time would be a small number of minutes.
Obviously you'd have to run a couple more trains via Ashford to utilise it, but naively I'd suggest it would still be cheaper than the major construction the southern access people are proposing.
SynthD
4 Apr 2020
The bus to Feltham exists, is it popular enough to show what’s needed? The point about southern, and western, access is about journey time, not feasibility.
Only a small minority of Heathrow passengers - something like 15% - are using T4. You’re then introducing another change for passengers to make it to their correct terminal.
The Ham
6 Jul 2012
Thing is, the Southern Approach to Heathrow would be far, far more useful than such a rope way.
For example in a post HS2 world Woking would be about +1 hour from any HS2 station than Euston by changing at Old Oak Common.
For example Birmingham in about 1:50 (with a circa 20 minute change at Old Oak Common) rather than fastest current journey time of 2:34 (which allows 50 minutes to get across London, which should be possible in 20 minutes). However, the big difference isn't necessarily the time saving, but rather the fact that it's a single change rather than getting from the main platforms at Waterloo to the Northern Line and then from the Northern Line to the main platforms at Euston
Likewise, the extra frequency of services between Guildford/Woking as well as Basingstoke/Farnborough and Farnborough/Woking (less so Basingstoke/Woking due to the fairly high frequency or already sees) would make rail travel much more attractive.
I've previously also suggested (given the limited time saving by running the trains semi fast from Basingstoke and that those wanting to save time would most likely be able to get a fat service and change at Woking, especially those not starting at Basingstoke) if the service was an all stations service beyond Woking you'd attract a lot of local rail travel.
You could potentially solve some of the junction issue at Basingstoke by (rather than a grade separated junction there) extending both the Heathrow and Basingstoke Stoppers services to Oakley (new station on the West of England Line) with a small amount of electrification or batteries.
The current Basingstoke Stoppers would probably need to cross to the London bound platform at Oakley to ensure that they were out of the way of the following WofE Line service (about 8 minutes later) and the return (some times) would have to be squeezed between the WofE Line service and the XC at Basingstoke (which may involve being held at a signal and/or the stopper running from platform 3 whilst the faster train running from platform 4).
The Heathrow services would likely be an easier fit in comparison.
Also, you need to consider the third runway is taking about +50% more flights, there's almost no way you could run that many extra flights and be reliant on road travel to get them to the airport.
At 500 passengers an hour (9,000 a day), assuming £15 a ticket over a year that's £48 million for 10 coach trains (well 8 coach trains but +2 coaches per train to allow for spares) just between Heathrow and Woking, that's enough to cover the likely running costs of the trains (assuming £200,000 per coach in lease costs and that's 1/3 of the total running costs).
Now, is likely that Woking to Heathrow at £15 for one way is very likely to be a too high (RailAir from Woking for a single is £11 and a return is the equivalent of £8.25 each way).
However, that's assuming an average of 125 people per train and not considering that you may find staff using it as well as passengers as well as other travel it generates.
If we were looking to set ticket prices at an average of £8 (so to undercut RailAir) from Woking and beyond, rather than 125 people per hour you'd need 230. However, that wouldn't even need to be all Heathrow based travel.
For example, 3 extra people travelling Fleet to Woking would reduce that count by 1.
Also, a passenger travelling from Farnborough to Old Oak Common with a ticket of (say) £16 would reduce that passenger count by 2.
Finally £8 is probably a little low for the average cost, as at Woking you only need to be an average of £8 to undercut RailAir's standard return, from Woking that might be £14 (£7 each way). For a standard off peak return to Woking from Guildford £4.90 whilst from Basingstoke it's £11.50, so for through ticketing (where most of those travelling would take the direct train rather than changing) to generate an average of £16 return, each leg could be £6 extra, or £17 return from Guildford and £23.50 from Basingstoke.
Given that petrol costs would be circa £25 return from Basingstoke to Heathrow those ticket prices would undercut driving for someone going on their own and with parking it could still be fairly good value for 3 or maybe even 4 people going if they were going for a longer holiday.
If prices were at that level, it would attract quite a lot of current travellers, even before you consider the uplift from the extra capacity for local travel.
If prices were higher then the number of passengers you'd need per train would reduce. Also, bear in mind that's on off peak prices, so peak prices would drag the average up a little.
Anyway 230 people on a train capable of carrying over 400 people, which would be busy people could get a pair of seats too themselves except those travelling together who may take a pair of seats or three out of four, as such it would be fairly busy, but not so much that any would have to stand (except at peak times, but then other trains would be much quieter)
