150222
- Joined
- 9 Jul 2011
- Messages
- 1,002
Like the title says. What is going on in the Halifax/Brighouse area? I heard something about a points failure. How are services affected?
A signalling problem is causing disruption at Mirfield and buses are replacing trains between Huddersfield and Leeds/Halifax, with journey times extended by up to 30 minutes. This will continue until further notice. First TransPennine Express customers may use CrossCountry services between Leeds and York.
Chaos at Manchester Picc. I arrived there at 1330 and the next train to Huddersfield/Leeds was the 1442 to Hull, which ran as a double 170 after the 1342 was cancelled. Loads of unhappy people. 4 RPIs on Platform 2/3 whod been told hardly anything.
The 1357 to Middlesbrough arrived in at 1410 but didn't depart until gone 1448 because there was no guard. I got off it once that was said at 1415 and went fo wait for a train home.
but moving forward 200 yards and then stopping for 10 mins, repeated for 3 times, is not a good sign and infuriates passengers.
200 yards might be a bit of an exaggeration - when there is signalling problems the train might only be able to move between one signal at a time (which does seem stop-start), but there is nothing much that the driver can do until they can get permission to go through the problem area and clear the blockage.
I'm sure everyone would rather get there safely but slowly rather than not at all.
To be fair they'd probably be better off if they got a bus from the previous stop. (Is that Slaithwaite?)
It would be but you have to think of the further complications this would case - setting trains behind back several signals, and then the cost and time of laying on buses.
Of course but also if people were told at Slaithwaite that it would be 40 mins to get to Huddersfield, people may have got taxis in order not to miss the kick off. ****ed up football fans need to be treated with care rather than shunted on to something they are effectively prisoners onto. As ever, more information please.
Slaithwaite is the next stop west of Huddersfield. However detemining the length of delays is very difficult until someone can get to the area and see what has happened - I've been on a few trains where we were only supposed to be slightly delayed but when it turned out that cable had been nicked, then it took a lot longer (and conversely I've been on trains where we've been told to expect the worst but then have been able to get through quite quickly).
The issue of replacement buses is also a difficult one - trying to arrange buses to be at a station, to get a driver out on it and also get other staff to help is nothing short of a nightmare at short notice.
Taking your point about football fans - they are no different to any other pasenger on the train. Also, in this situation the delays were happening since 09.00 this morning, so they have had plenty of time to arrnage either going by bus or taxi.
I agree that the lack of information is the biggest problem - and this is across the industry. However it is no doubt impossible to predict what a problem like this will have on services. My point is that if people knew that there were delays to services from this morning, then turning up at Slaithwaite for the hourly service right before the football match is unwise. Certainly in this situation looksing at or ringing National Rail Enquiries/Traveline/Metro travel centre for info would have been my first action.
Going to your point about football fans again - yes I'm sure Northern know that this train is likely to have football fans but that is not going to shift it any faster and get them there quicker. They are no different to any other passenger and would have to wait their turn.
People turn up at the station and expect normality, then expect information if things aren't going to plan
How realistic this is I don't know as I can only comment for myself - if I knew there were going to be delays then I'd plan accordingly. If I'm setting out for a long trip in the car then I'll check to see if there are any accidents/roadworks/delays near to where I am. I also mostly will check the live departure boards online if I'm going on a train journey long distance before I set out for the station (force of habit due to being stuck somewhere when I didn't check, and delays happened).
It's a good point. How many people do check to see if there's any train problems? I suspect fewer than the percentage of road-goers who check likewise.
Probably not many - they are more likely to check for info there and then when they realise the extent of the problems. Even though info/communication could be much better at times when you think about it you can check for delays on BBC red button, the internet, on your phone or by calling several different numbers, and most people will know at least one of these methods. Plus delays are normally announced on radio and local news on TV.
As far as I see it, there are four main problems: firstly, many people assume that since public transport works pretty smoothly for the majority of their journeys, it will run OK for any journey (it's surprising how quickly people's "anger" can subside and they forget about a lengthy delay that they experienced any more than a week ago). Secondly, many people are pretty bored even at the idea of reading a LDB on the internet - bizarre, since it takes all of 60 seconds to do. Thirdly, and most importantly, in a major disruption situation, some people will be put off by the fact that there is often a great deal of conflicting information from various sources - websites, announcements, phone lines, staff, etc. Fourthly, a lot of people are lazy and just don't think to check.
Slight rant over![]()
