From the post-HS2 WCML thread...
XC is an interesting question. If there's going to be 2tph of HS2 Manchester-Brum services, but Liverpool is unchanged, it could well be worth diverting the long distance XCs (i.e. the ones past Brum) to t'other end of t'M62 instead.
It might be worth with HS2 revisiting entirely what XC is for, because HS2 will unseat it as the fast service on many routes. It might be that it's best to split it up, or it might be that the original concept (relatively infrequent direct services for e.g. holidaymakers for whom too much changing is a big faff) is actually worth reviving in some form if they can be pathed, perhaps based on a two-hourly approach with splitting/joining.
What do others think? Does the idea of long distance direct services have value, or would we be better lopping up XC to the relevant local TOC and basing it around connections in Birmingham and London to/from HS2?
For the XC services what if there was a 2tph Liverpool to Oxford with 1tph extended to Bournemouth, and a South West/ Bristol to Manchester using Crewe as an interchange and timetabling so they arrive at similar times so Manchester can transfer to Oxford and Liverpool - Bristol. Birmingham can also be used for services from South West - Liverpool, and so on.
