I had a search but couldn’t find anything directly related. This is in no way a complaint, or a suggestion of how I think things should be different, I’m just curious to know how things are calculated.
This evening on my way back from York my LNER train was held outside of Retford as a passenger had taken ill on the Hull trains service in front.
Whilst the most important thing is to ensure the passenger is ok I did wonder how the associated costs (which will likely be tens of thousands of pounds) are worked out.
In this example. The train called at it’s booked stop (Retford) after starting at Doncaster (we don’t need to go into why it started short).
The LNER services that follows also calls at Retford. This stood blocking the up main for 10 minutes before a suitable path could be found to run wrong line and into platform 2. This delayed the service and I missed my connection due to this (still not a complaint).
The Hull Trains Service was cancelled as the person who was ill remained on the train for reasons that I’m sure were justified medically. All passengers (likely 200 or so) were put onto the LNER service. Many of those may have been on advances so ticket acceptance would be in place and the cost here would be substantial.
There would have been further HT passengers at Grantham. The LNER service ran late and may have fouled connections for LNER passengers at other stations. (For example it fouled the minimum connection time for the last connection of the day to Skegness although luckily that service itself was 10L) The LNER arrived much later than the HT service would have so every passenger is entitled to at least a 30 minute delay repay claim.
The return working of the HT (2030 from King’s Cross) was started short at Grantham so ticket acceptance was required on LNER once again. The HT is running about 25L so again could foul connections or if it misses a path could end up 30L and create another batch of claims.
For example had I required that service to get home from London today (it’s my last connection home from London Monday to Friday) I would have been stranded at Retford / Worksop.
So all in all the costs will be running into the tens of thousands. Is it HT that covers this or Network Rail? Is there an agreement between TOCs whereby ticket acceptance for this scenario comes with a reduced fee or does the already struggling to Survive Hull Trains just have to put it down as a cost of doing business?
