Mikey C
- Joined
- 11 Feb 2013
- Messages
- 7,562
Q) Why did TPE go for three different Nova fleets?
A) Because five different Nova fleets would have been silly
Also only around 4 sets required.Wrong gauge, and nothing in Ireland loco-wise with the same multiple working system.
i.e. expensive modifications would be required.
That’s really interesting, so not everything is quite as rosy in the Class 802 garden as some would have us believe.Isolated GU’s is not confined to TPE and not really related to depot capacity. The maintenance responsibility is split between Hitachi and MTU and sometimes fault finding whether it is a train side problem or an engine side problem takes time (too long, in my opinion). Material supply has also become a recent issue.
The engines are also operating a demanding duty cycle, so they go through items such as sump gaskets. If an engine is spewing out oil as a result of a leaking gasket, it will be isolated until the unit is programmed into a depot by the Hitachi CPU.
I didn’t realise about the 802s just stabling at Edge Hill, thank you for that. The acceleration of the 802s on diesel isn’t exactly sparkling when everything is working, I can only imagine they are pretty pedestrian with one GU out!Hitatchi struggle to maintain the 19 units that TPE currently have. There are a number of sets that have been running around with isolated GU's (engine) for weeks as well as other issues.
Doncaster and Craigentinny are the only locations where heavy maintenance can take place for TPE's. Hitatchi would need more suitable locations to carry out maintence work if TPE were to acquire additional 80x sets. Edge Hill would be an ideal location for maintence work, but Alstom own that site and don't permit 802s into the shed over the pits.
Many thanks for the reply. I hadn’t realised about the increased wear on the brake pads, that’s a very interesting point.On 2 x GUs, under the current timetable you can (signals permitting) keep time, even over the Pennines. The only real performance issue is on a Sunday when the sets run on diesel north of York. With a GU isolated, it will lose time.
Another thing to factor in is braking. With a GU isolated, the unit loses all dynamic braking and resorts to friction only - increasing the wear on the brake pads So yes - all is far from rosy with the 802s!
Personally, I think that the "Not enough capacity at Hitachi so had to make do with CAF" argument is incomplete, because it fails to answer the question of why on earth they decided to go for two separate CAF fleets.
Civity is supposed to be a modular platform, is it not? So why could they not have build a fleet of 397s, but with diesel drivetrain rather than electric?
Alternatively, why could they not have ordered entirely Mk5s and just hauled them with a small fleet of electric locos on the Scotland services? There's not exactly a shortage of them, with both the IC225s and Anglia sets coming off-lease.
I agree that doesn't explain why they weren't used on the WCML with electric locomotives, though.
By the time the 350s went to the West Midlands, there would surely have been some 91s available?Probably because none were available quickly.
Re the suggestions of using ex IC225 or Anglia locos..
Would 90s or 91s have been suitable for working with Mk5 stock given their age and making them compatible with the control systems? They'd hardly be rapid, so good luck keeping to timings in between far quicker stock...never mind the additional question of replacement in 10 or so years time.
For one, you can double dock a 70m long 323 at Manchester Airport with a 118m long 397. You can't with a 133m long Nova 3. Platform capacity is infamously constrained there even with the current 4 platforms, so this adds considerable operational flexibility.I agree that doesn't explain why they weren't used on the WCML with electric locomotives, though.
Didn't the 68 / 88 order have something to do with First's bid for the Caledonian Sleeper and using them on TransPennine effectively was a fall back.Probably because none were available quickly. The Class 68 production line was open at the time of the order.
DRS may also not have been keen on more 88s - the lifetime of the locos is much longer than the current lease contract, and 68s are more versatile.
Another option might have been to order a larger fleet of 397s instead of the Mk5a's and to specify Mk5a-like interfaces to enable them to be 68-hauled over the Pennines. Then TPE would have had only two new fleets, and they would have been "electrification ready".The reason for going with Mk5s was fast delivery - they were a continuation of the Caledonian Sleeper order built on the same jigs. That's why they are 22m long and have the "posher" interior, e.g. all metal-panelled rather than the plastic of the rest of the CAF kit.
From the passenger perspective, brand new carriages hauled by old high speed locomotives is still new stock...The whole point was that they were having a new fleet -this was a big marketing point. Why would they use locos which are over 30 years old? Would the ROSCO even have agreed to fund the stock on that basis?
I don't understand why speed was such a concern. After all, TPE already had a relatively modern fleet with nowhere clear for it to be cascaded to (apart from the 350s to WM, which could have hung on for a bit longer if needs had been as its only purpose was a modest capacity increase)It would be speed again - the theory was that the Mk5a sets could be built quickly, and would be the first of the new fleets to arrive. That wouldn't have happened with extra EMUs, especially if they'd had to design some sort of multi-working system with locos (it's worth noting that it's many years since any such system has been used for new stock in this country - think the last time was SR EMUs which could work with 73s and 33s).
You obviously haven’t travelled from Leeds to Manchester in the evening peak on a 3-car Class 185! Longer trains were needed around 2010, bringing the 350s in made more 185s available but resulted in the loss of the 170s. By 2018, things were at breaking point.I don't understand why speed was such a concern.
According to the Sectional Appendix, the Local Instruction for permissive working at Manchester Airport only allows platform sharing when both trains have four or less vehicles. So a 5-car 397 must have a platform to itself.For one, you can double dock a 70m long 323 at Manchester Airport with a 118m long 397. You can't with a 133m long Nova 3. Platform capacity is infamously constrained there even with the current 4 platforms, so this adds considerable operational flexibility.
The multi-working system would have been similar to the one that had to be developed for the Mk5a sets anyway. A Mk5a set is pretty much an unpowered MU.It would be speed again - the theory was that the Mk5a sets could be built quickly, and would be the first of the new fleets to arrive. That wouldn't have happened with extra EMUs, especially if they'd had to design some sort of multi-working system with locos (it's worth noting that it's many years since any such system has been used for new stock in this country - think the last time was SR EMUs which could work with 73s and 33s).
Ah quite right you are, I think that's a signalling restriction? There's no physical reason why that need be the case.According to the Sectional Appendix, the Local Instruction for permissive working at Manchester Airport only allows platform sharing when both trains have four or less vehicles. So a 5-car 397 must have a platform to itself
