Why didn’t BR order class 455s for South Eastern?
61653 HTAFC
18 Dec 2012
Another planet...
That must explain the part of the side of one carriage which has no windows, except a little one at the end. Judging by the length of it, it must have been a pretty large khazi!
They wouldn't have been big enough for next year, if they hadn't been ripped out!
Surprising that they didn't replace the window with a standard one though.
Journeyman
16 Apr 2014
They sort-of were, though with a 321-style cab. Also they had toilets from new which were removed by Southern.
They also had 321-style seats, which were much better than the ghastly low-backed seating fitted to 455s.
Journeyman
16 Apr 2014
The South Eastern has historically been tight for gauge clearance, so I believe that there are also issues to do with restricted clearances on some routes on the SE that would preclude the operation of 455s, 456s or other Mark 3-based stock, hence the decision to order the Class 465/466 Networkers rather than a Class 455/456 derivative.
The Networkers needed a LOT of gauging work to be carried out before they could operate throughout the South Eastern suburban network. It was all part of the upgrade package, but I remember a Daily Mail "British Rail orders trains too big for tunnels!" headline at the time.
Journeyman
16 Apr 2014
Are the Networkers to big for the Central? You often see signs around the Battersea/Victoria area that say “Networker X” where the eastern and central connects.
That's more an electrical interference issue than anything else. Networkers use an early form of three-phase AC motors, and the control equipment produces interference at a particular frequency that can affect signaling. A lot of immunization was needed on the routes where they operate.
The problem is actually the control equipment rather than the motors. Networkers use GTO thyristors that can only switch a few hundred times a second, within the range of frequencies used by track circuits and other equipment. Later EMUs have IGBTs that can switch much faster so have much less scope to interfere. I don't think there's any reason why the older traction motors couldn't be controlled by the IGBTs (they are on 323s but only at the original switching frequencies - not sure whether the Hitachi-powered Networkers got new motors).
