* Another bus with the same number already stopped doesn't count - with most buses you can't see from the back that it's not turning short, for example.
Buses turning short also posed a problem in the past in Hong Kong, too many passengers did not look at the destination plate, because buses turning short only exist on a small handful of busy routes in the city centre.
And now, the bus companies do the following on short turning buses:
- Reverse the position of destination and number on the front plate, such that the number is on the left instead of on the right
- Put a large notice at the farebox
- Instruct the driver to speak out the destination when passengers are boarding
- Invert the colour on the side and back plates, but because it may be hard to read, now it adds a box around the number on the side and back plates.
This allows passengers to easily identify if it is a short turning bus even if they catch the bus from behind.
However, there are still situations where buses overtake the others on the same route lead to complaint. For example, at a well-known busy stop in the peak hours, the first bus overloaded but the second or third bus on the same route with capacity overtook it without stopping. One of the routes I use in the past were timetabled so badly to have departures from 3 termini running on 4 route variants in peak hour (1 regular route, 2 departing from later stops, 1 skipping some intermediate stops) as an attempt to cope with the huge passenger demand just before the bus goes on the motorway, and the timetable frequently results in 3 or even 4 buses bunching together once the variants joined.
That too many bus drivers don't put enough effort into ensuring they are seen at stops, and instead just pull out to overtake? Clearly it is hard to evidence that unless I was to stand filming buses for an hour (and you'd see it happen several times at a number of stops I know in that time), but I'd suggest you try standing by the stops on Midsummer Boulevard in MK for about half an hour or so, or any stop on Wilmslow Road in Manchester, and you will see it. Any regular user of bus routes which have busy stops with multiple routes will have experienced it to some extent.
This is a frequent occurrence in morebus here in Bournemouth and Poole. Drivers like to pull out and overtake other buses at bus stops even on a single carriageway with only one lane in each direction, especially on the routes m1/m2.
Also, I believe some drivers are not paying enough attention at the bus stops while the route is approaching the final stations. For example, in an evening, I was at Lansdowne wanting to go to Bournemouth town centre, and I saw a 13, a long distance route coming outside BCP to Bournemouth. I raised my arm and waved at it from a distance and the bus didn't show any sign of slowing down. Finally the bus driver saw me and stopped, but it was already ahead of the bus stop.
