In fact they were just constrained by what was commercially available from the main manufacturers. You can't have what you can't buy. The USA overcame it by adding multiple locos to the formation, initially four was a standard, and the earliest US passenger diesels like the E-units had two engines in each, but the costs and waste of space are considerable.BR did seem to persistently underestimate the power output required of a diesel to match a given class of steam, which is a bit odd,
Gerry Fiennes understood the need to avoid skimping on diesel power output but not a lot of other people did. He kept asking for a 4000hp locomotive, but they never gave him any.
In Britain for some rerason double-heading by large diesels never worked out. The Western Region had a couple of shots at it and found that it only knocked a few minutes off. Likewise Crewe to Glasgow while it was being electrified, if one of the pair was unavailable only a small delay. The only area where it worked out was Scotland, where for a generation Inverness to Glasgow/Edinburgh normally ran with double headed Type 2s, and the well-known Edinburgh-Glasgow push-pull. This was all because they were not given adequate main line locos, and when these became available they ran in the same timings.
Gerry Fiennes actually wrote that he was asked why not double head, and pointed out that on a terminus turnround at Kings Cross in the space available you would end up with just a couple of coaches in the train. The thing about adding units is that it only benefits you in initially accelerating to line speed, which on a long nonstop run is not very much, but you have the costs of the second unit throughout the trip.
Took long enough; the 567C didn't come along until the mid-1950s, more than 15 years after the 567 introduction and by which time much dieselisation was completed. GM did offer a B-C conversion for those with fairly new 567B engines, but it was quite an expense with a substantial variation to the cooling, and GM priced such that trading in for a complete new loco looked equally attractive.The mechanical radiator shutters on GM locos was only on the FT model from 1939 to 1946. They later went to AC motor driven fans from 1947 onwards.
The early 567 engines did have water leaks that were eliminated on the 567C model engine.
The FT was produced with so many units that there were plenty still running round in the 1960s. Unlike being in the heated cab (or likewise, in "winterised" steam loco cabs), the fireman running up and down the units as the train ran at speed with the Midwest harsh winters blasting in at -20C through the extensively louvred loco sides, through all the leaked coolant now frozen, was not for the faint-hearted.
And we think the Co-Bo was bad ...
