Worcestershire Parkway station progress
Sprinter107
26 Mar 2019
That wouldnt be a bad idea. Reckon theres enough turnaround time on some trains at Shrub Hill to run up there and back. A little bit of tweeking, and I'm sure it would work.
Parallel
9 Dec 2013
I wonder if it would be possible to extend a Shrub Hill to Moor Street train to Worcestershire Parkway High Level instead. It might not do for the South West but it maybe able to provide more services into Birmingham (Snow Hill Lines). Change at Shrub Hill for the South West.
Would it really be necessary to go from Parkway to Shrub Hill to go to the South West? Worcester Shrub Hill currently only gets 1tp2h towards the SW. Surely it would make more sense to just catch a southbound XC service at Parkway and change at Cheltenham Spa? Unless you were going to Ashchurch but I can’t imagine many people will drive to Parkway to then take a train to Ashchurch.
Can they reverse a train at Parkway High Level? It would be quite a slow journey into Birmingham compared with XC with one stop from the low level platforms.
si404
28 Dec 2012
I'd suggest that extending Snow Hill line trains to Parkway is about linking Stourbridge and Kidderminster with, and also improving frequency from Central Worcester to, the car park and train service southwards, rather than providing another route into Birmingham.
Xenophon PCDGS
17 Apr 2011
Perhaps my somewhat old age has caught up with me yet again and not being knowledgeable about the Worcestershire area, but are there to be both low-level and high-level platforms at this proposed station....or have I mis-read some recent postings on this thread?
Does any one know when the last railway station having both low-level and high-level platforms was opened?
si404
28 Dec 2012
Yes high level (North Cotswolds line) and low level (Cross Country Main Line) platforms.
Monument (Tyne and Wear Metro) or Canning Town was the last station to be built as a two level (depending on if Canning Town counts) station rather than simply adding a level to an existing station.
Obviously, had stuff gone to plan, Liverpool Street, Farringdon and Paddington would have been stations gaining low level platforms about a year ago. St Pancras gained low level platforms in 2007 so that is the winner, AFAICS in the most-recent to go two-level stakes.
Yes, there are two low-level platforms on Birmingham-Cheltenham and one high-level on the Cotswold line which is single track (but I believe there is space to add a second platform if it is ever doubled).
I think Smethwick Galton Bridge was the last totally new two-level station.
Tobbes
12 Aug 2012
What are the chances of a full re-doubling of the Cotswold Line? Electrification in CP7 would be nice, of course.
si404
28 Dec 2012
Unless Canning Town counts - the oldest platforms (ex-NLL) still there are a month younger than Smethwick GB and the timescale suggests the original 1994 DLR platforms that were the first on the site were never meant to be anything other than a temporary bodge while they built the final station (they closed less than 2 years later for placement in their final position).
Liverpool South Parkway in 2006 is possibly the case, though it seems to be a rebuild of Allerton, rather than a new station. Gaston formally closed (despite simply moving such a short distance that the platforms nearly adjoined) but Allerton didn't.
6026KingJohn
8 May 2019
How about - Run Birmingham - Hereford as 2 x 170 from New Street to Bromsgrove, then split and one unit continues to Hereford as normal, second set continues to Worcester Parkway, Ashchurch, Cheltenham and Gloucester. WMT used to have a service to Gloucester (albeit 1 train late on Friday night returning ECS to Worcester) suggesting Worcester crews may still have route knowledge.
VT 390
7 Dec 2018
But really if extra carriages could be found for the Hereford route (not 170's as these are being replaced) they need to be used all the way through to Hereford as these services are usually very busy.
Ianno87
3 May 2015
I get the impression that loads from Droitwich/Worcester easily justify 3/4 cars just in themselves.
si404
28 Dec 2012
The plans (both Midlands Connect and Network Rail) are for 2tph to both Hereford and Cardiff. Needs Kings Norton-Barnt Green 4-tracking and the Bordesley curves, so it will be about a decade before it's possible.
takno
Because Worcestershire Parkway isn't on the route from Worcester to Cheltenham
takno
But it is on the route from Bromsgrove to Cheltenham, as was 6026KingJohn's suggestion.
Oh right, misread it, although in that case you'd certainly want all four cars to go to Worcester, unless you believe that the people currently ramming onto those trains at Worcester all secretly want to drive out to middle of nowhere to get the train instead
jimm
6 Apr 2012
Nothing to do with Parkway but WMR is promising longer trains on the Hereford service. When that will be remains to be seen. On current evidence not until the new Class 196 dmus start to arrive from CAF.
PartyOperator
26 May 2019
An alternative to XC on the Birmingham to Cheltenham/Gloucester route would be very welcome too. Those trains are already rammed (and very expensive).
jimm
6 Apr 2012
A more sensible measure would just be to provide XC trains on both the Bristol and Cardiff routes of a sensible length and seating capacity and increase the frequency of the GWR service between Bristol, Worcester and Great Malvern to hourly - rather than chewing up yet more paths with yet more short dmus.
HowardGWR
30 Jan 2013
It physically couldnt call at both Shrub Hill and Parkway if it was heading South West. Parkway is the wrong side of Abbotswood Junction.
Yes I know that, which is why I wrote that one was an alternative for the other stop, not both, in respect of interchange possibilities.
SoccerHQ
29 Aug 2018
Depends really. I travel to Bristol once a month due to relatives down there and often get back around 5pm. Certainly it's standing from Temple Meads up to Cheltenham but once you get there half the train gets off and you can find seats easily enough even if it's just a 4 car service. Add in a couple of those 7 cars a day and there's plenty of capacity to fit in 15-20 getting on from Parkway afternoon/early evening. Surely one of the two XC from Bristol hourly could stop? You also usually have dwell time at New Street aswell, the 19.03 to Leeds usually rolls in at five to seven.
Ianno87
3 May 2015
Doesn't matter if there's dwell time spare at New St - it's got to hit its path between CrossCity trains at Kings Norton.
SoccerHQ
29 Aug 2018
Yes true although often you'll see a CC train held back at Kings Norton waiting for XC one to pass so at least we don't have single track all the way from Longbridge as that would cause massive issues.
Also the train going to the North east usually goes the Kings Heath route so less of an issue and that too comes into New Street just after 20 past, dosen't depart until half past the hour. Perhaps that can be the train that stops at Parkway?
HowardGWR
30 Jan 2013
We seem to have diverted from the pure infrastructure theme but all these suggestions arise from the fact that XC does not run through Shrub Hill and people around Worcester are wedded (perhaps necessarily) to the car.
father_jack
26 Jan 2010
Cheltenham to Bristol TM and VV fares are artificially low. GWR price the flow but only run a train every 2 hours that goes via Gloucester. I'll let someone else explain why/ "Cheap day"/ off peak day returns are code W5, 0830 and after. That's why the split tickets work.
SoccerHQ
29 Aug 2018
Yes it's good value, 10 quid return from Cheltenham to Bristol for 40 minute journey whereas same journey time from Chelts to New Street is 26 quid return.
Actually I hadn't thought of that regarding split tickets. From memory Cheltenham to Worcester is around a tenner and then from Worcester to Birmingham station is about eight quid. With a spot at Parkway you'd assume fares would be similar ish to the main stations 2-3 miles away so chance possibly to save a bit through split ticketting.
Sprinter107
26 Mar 2019
I'm sure the booking clerk at work was saying the fare from Worcestershire Parkway to Birmingham will be much higher than from the 2 current Worcester stations. Think Cross Country may be setting that fare, but I'll stand corrected on that.
II
28 Dec 2016
In terms of the station itself, I reckon a December TT change opening date may well be on, but I can't see it being earlier.
6026KingJohn
8 May 2019
I only mentioned class 170 as that is what is currently used. Probably better to use 3x172 2 car sets and send 4 to Worcester and 2 to Gloucester. The original idea of splitting/joining a train at Bromsgrove was to save a path in and out of New street by using an existing service to serve two destinations.
