Interestingly, the ETCS specs include provision for both dividing trains on the move (i.e. slipping), and also joining trains on the move. Whether they will ever be implemented is another matter. However, I suspect that it wouldn't have got into the specs if at least one country wasn't still doing it at the time, or at least thinking of it. Are there any other countries that still do slipping? Or attaching/detaching bankers on the move?
With self-driving cars on the horizon and driverless (and cab-less lorries) delivering on public roads ...
https://www.reuters.com/article/us-einride-autonomous-sweden/driverless-electric-truck-starts-deliveries-on-swedish-public-road-idUSKCN1SL0NC
... rail is being left behind. The advent of SD vehicles is another nail in the coffin because rail's advantages of a far lower driver-per-passenger or driver-per-freight-ton ratios than road, and the ability to transport people who cannot drive (or do not wish to), are shortly going to vanish.
The infrastructure for driverless trains is largely already in place (the steering problem is solved for a start) - yet we cannot handle a slip coach ?
With the ETCS provisions outlined above, and a largely multiple unit railway, the process of "slipping" a unit in the future could well be easier and safer than in the past. For one thing, rather than dropping off unpowered vehicles that need a station pilot to clear them from a platform, a DMU can move under it's own power to sidings.Detaching bankers is still practised. The Geislinger Steige (Incline) east of Stuttgart in Germany is one, and AFAIK the incline at Liege. This includes passenger trains at Geislingen occasionally, and possibly at Liege.
Slipping off one unit of a Portsmouth or Southampton-bound EMU at Woking (which has a London facing centre bay platform) comes to my mind. It would take five minutes off the journey time of the otherwise stopping Portsmouth train, which would also be saved from travelling half-empty beyond Woking (where a lot of commuters get off).With multiple units where both portions of the train are powered should make it easier
Good point:Clearly not, no.
Also, perhaps you could help people understand what the practice was, perhaps by linking to an existing explanation and quoting from it, for the benefit of anyone who doesn't know.
https://en.m.wikipedia.org/wiki/Slip_coachA slip coach or slip carriage is a British and Irishrailway term for passenger rolling stock that is uncoupled from an express train while the train is in motion, then slowed by a guard in the coach using the brakes, bringing it to a stop at the next station. The coach was thus said to be slipped from its train. This allowed passengers to alight at an intermediate station without the main train having to stop, thus improving the journey time of the main train. In an era when the railway companies were highly competitive, they strove to keep journey times as short as possible, avoiding intermediate stops wherever possible.
A modern implementation of splitting and joining on the move under ETCS would have to incorporate an effective 'virtual coupling' between the units involved that would have to remain engaged while the operation took place as long as the parts were less than a conventional braking distance apart. Virtual coupling is a concept being investigated anyway to allow multiple separately powered units to work together as a combined service without them having to be coupled together physically at all. That could be of great use on its own for speedy splitting and joining at stations, without the additional factors involved in accomplishing such operations on the move. Part of the virtual coupling concept is a real-time high-integrity wireless linking of the traction and braking control systems on the units working together. To be fully fail-safe the rear unit will have to engage an immediate full emergency brake application should the link fail or become compromised in other ways.
Interesting; I can see this idea could potentially give considerable capacity increases on very busy sections of the network, e.g. 3x4 coach trains leaving a major station simultaneously to different eventual destinations, all sharing the same path as a single 'virtual train' and potentially 'virtually splitting' dynamically at junctions (I guess you'd need to split the virtual train dynamically into two portions occupying two paths as it approached the junction to ensure the points could be changed safely between the two portions). But with solid realtime comms between the parts of the virtual train all sorts of interesting possibilities would arise.
Seamless Interchangeability (DC NOTE: that's what CU called the concept) involves the running of a non-stop 'train', known as the 'prime train' between the terminal stations. To serve intermediate stations, autonomously powered carriages couple/uncouple from the front/rear of the prime train. This allows passengers to travel from an intermediate station and join the 'quicker' non-stop train,o giving passengers the option to walk through and change trains without stopping. The concept benefits were highlighted using a developed fictitious railway network simulation model, allowing today's operation to be compared to that of Seamless Interchangeability
That must have happens when slip coaches were regularly used. I'm not saying it was right and it may even be a good reason for it not to return. I'm no expert but I am interested in itUntil a cow/ road vehicle/ suicidal person/ p way staff member appears in front of the leading train resulting in an emergency brake application ...
Well they don't of they don't alight before the portions split.All well and good till someone is in the wrong portion and gets carried to here they dont want to go - hell it even happens now but at least people get a second bite at the cherry so it is to move.
Though self-driving road vehicles would be able to be packed far closer together than is safe with a meatpuppet behind the wheel...Apart from other issues, this ignores an obvious advantage of railways. It would be impossible for all London commuting to be done by car, self driving or otherwise. The road capacity is simply not available. Self driving cars may make congestion worse, if the cars are shared and have to drive between set down and pick up points, or to car parks, or if they drive around to avoid paying for parking.
The system would rely on continuous, dependable, low-latency communication between the units involved. The emergency brakes would apply on all units simultaneously.Until a cow/ road vehicle/ suicidal person/ p way staff member appears in front of the leading train resulting in an emergency brake application ...
Indeed. Commuter railways are not under threat from SD vehicles, but other railways (including all freight) are. If SD cars are used for commuting into cities the problem remains, as now, of parking them during the day. SD cars will "solve" this either by being sent all the way back home empty, to be recalled in the afternoon, or else they will be programmed to drive in circles round the block all day. So even more congestion.It would be impossible for all London commuting to be done by car, self driving or otherwise.. ... Self driving cars may make congestion worse
Cars are already driven by the meatpuppets far closer together than they should be, and in towns they are often moving so slowly that the officially recommended spacing is small anyway. In fact a frequent criticism of SD cars is that they will be programmed to keep recommended spacing (it cannot be otherwise) and will therefore reduce the road carrying capacity by this factor alone. Or are SD vehicles going to be exempt from the requirement to leave spacings at least greater than the stopping distance, while the requirement remains in force for trains?Though self-driving road vehicles would be able to be packed far closer together than is safe with a meatpuppet behind the wheel...
