T
Tom
Guest
Look at this image!
Only if it does indeed stay as a rail terminal and is handed over to SWT1288gaje said:don't be surprised because it may be possible that you may get a 450 in the Eurostar terminal 8)
Coxster said:Only if it does indeed stay as a rail terminal and is handed over to SWT![]()
IMHO it would be alright if they filled in the bit downstairs at Waterloo where the gates are to get into the Eurostar terminal. Then it'd be flat and they could make it look like the rest of waterloo.HBA135 said:Coxster said:Only if it does indeed stay as a rail terminal and is handed over to SWT![]()
It most probabaly will, as SWT need more platforms at Waterloo and around 20 length coach platform would be ideal for SWT as they could fit in 2 10 car 444 desiros, or maybe a 12 car 450 and an 8 car 458, or SWT maybe shorten and then again they may re-build the terminal so it fits in with the main Waterloo station.
Coxster said:IMHO it would be alright if they filled in the bit downstairs at Waterloo where the gates are to get into the Eurostar terminal. Then it'd be flat and they could make it look like the rest of waterloo.
