Advanced Ticket: Different London Terminals
Sun!
13 Nov 2010
Hi,
I'm travelling on an Advanced ticket from South Wales to North Kent.
My train obviously arrives at London Paddington and then will depart from London St. Pancras.
What is the best way to get between the two station during the early afternoon? Does the ticket include tube/ bus travel?
One thing to note is that I will have a large and heavy (25-30kg) suitcase and a smaller piece of hand luggage. Will this make the tube impossible?
1E05
11 Feb 2010
You may find it easier by bus but you will have to pay £2.40 unless you have an Oyster card when it will be £1.35. If your ticket has a + (plus sign) next to your destination it is valid on any tube line between your London terminals.
That was suppose to read cash single bus fare 2pound 40 or oyster fare 1pound35p
Qwerty133
7 Oct 2012
Leicester/Sheffield
tube is definitely possible with 2 pieces of luggage and is quite easy at paddington however if i remember correctly it is quite a walk between the tube and mainline platforms at st pancras
34D
9 Feb 2011
For deep level tube I would agree with you. However this journey is SSL.
At Paddington, if the OP goes to platforms 15/16 and gets an Eastbound underground train, this will stop at St Pancras (sub-surface platforms) from where the SouthEastern platforms are a short walk.
bb21
Emeritus Moderator
4 Feb 2010
You can get a bus if you wish and the one you require is the 205. You have to pay separately as already mentioned.
If you have one through ticket for the journey then under the Route field it should have a + sign, which gives you a free cross-London transfer on LU. From Paddington, you exit the stairs in the middle of the platforms onto the overbridge and follow the signs to Circle and Hammersmith & City lines. The journey takes around 12 minutes.
It is not recommended to use deep-level tubes.
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
I took the Hammersmith and Circle line from Paddington to St Pancras with luggage during peak time, and it was very busy. There was a queue to actually get on to the platform at Padd.
It is still the best way to go though, as the alternative is a long walk to the District/Circle platforms and then a change at Edgeware Road.
Usually, you will be close to the stairs to the Hammersmith line when alighting from a South Wales HST. It's a long old walk to the bus stops with bags as well.
maniacmartin
Fares Advisor
15 May 2012
Croydon
The Bakerloo and Victoria lines are also quite quick, although I wouldn't recommend them in this case as you have heavy luggage
Be3G
14 Sep 2012
Chingford
Whilst using the Hammersmith & City Line might be quickest, that does involve stairs – whereas I think a step-free route is possible by catching the Circle (not District) line to Edgware Road, and changing to a tube to King's Cross. (Source: this)
MikeWh
15 Jun 2010
Crayford
Oyster PAYG bus fare is £1.40.
Qwerty133
7 Oct 2012
Leicester/Sheffield
I think you have to go over a bridge which only has stairs at edgeware road and with the number of people changing it is quite difficult to get to other platform quickly.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
As Be3G said, that is only if you arrive at Edgeware Road on a terminating District Line train. If you arrive on a terminating (i.e. eastbound) Circle Line train then it is a cross-platform change to continue eastwards on either a Circle or Hammersmith & City line train.
I got confused by the layout and train destination indicators at Edgware Road when in London recently and ended up heading back towards Paddington having just arrived from there! But at least a consequence I have a better understanding of the platform operations...
island
30 Dec 2010
Note that Advance tickets are not accepted from St. Pancras Intl to Kent in the evening peak.
