A bit more on this. The difference is linked, though not in a straightforward way, to the wiring of the traction motors.
All of the locos with TG 160-60 generators are series parallel.
For the loco to be all parallel it has to have a TG 172-50 generator.
The complicated bit is that there were a small number of locos built at Loughborough that had the TG 172-50 generator but nevertheless were series parallel. These were D1682-1701 and D1707-14, later 47096-113 and 47119-124. The only ETH fitted locos in this batch were 47486 and 47487, which spent a while at Stratford and did not have a good reputation.
If they all had generators (and not alternators) why were only the first batch (1500-19 aka 47401-20) known as "Generators". was it something to do with them being fitted for ETH from new, whereas it was retro-fitted to later members?
That is down to the way that the ETH power is supplied. D1500-19 ETH was powered by a separate generator, the others had ETH powered by a dual wound alternator.
