SpacePhoenix
- Joined
- 18 Mar 2014
- Messages
- 5,492
How much extra load does having a plug socket per seat place on the 3rd rail?
I've made a separate thread on phones, so you can debate about interfaces on that and leave the poor 707s alone
Over here=http://www.railforums.co.uk/showthread.php?t=134223
Purpose-built commuter trans normally carry more standing than seated when fully loaded. So when all the seats have been grabbed, those standing can be no less in need for mobile power than the lucky seated ones. Therefore the problem is to get enough outlets for everybody just to keep it fair. That's about 150 per car for Desiro City of Aventra designs.
Bring back old LU style bobble hangers but with a USB-A socket in the bobble?
Imagine the number of cracks on the phones with people bumping into them
DB's Talent 2s have USB points located up near the luggage racks. I guess this is to allow use by standing passengers.
Londonist drives a 707:
https://www.youtube.com/watch?v=TiuWtJP3MbM
I wonder if drivers of 444s and 450s will find many differences in the handling of them compared with the 707s
In the September Modern Railways, the vehicle designations are given as follows:
DMOC/S (B)
PTOSL
TOS2
TOSLW
DMOC/S (A)
Normally L means toilet - the article mentions they have none.
DMOC usually means composite, i.e. first and standard
DMOS usually means standard only - the units have always been described as standard only, so what does C/S actually mean??
Interesting how only two of five coaches are powered. One would normally expect three?
Indeed, seems strange. Could it be a typo? The 700s have 50% motor cars
And the Class 345 is reportedly 90%!
Note the reason for the L is fact they have certain work for a toilet to be installed in the future (think pipe holes in body etc).
But Bombardier typically don't have all axles on the motor coach powered so 377s were only 2 motored axles per motor car and 378s 3 motored axles per motor car...
The traction motors in the 345s are apparently smaller* and lighter to fit inside the inside frame bogies, allow disc brakes on motor axles unlike the 700s and more effeicient regenerative braking.
*Power output very similar to an EE507 so less powerful than some recent motors on Bombardier or Siemens stock. Aren't the Desiro City motors also a bit smaller and less powerful then the Desiro ones?
The 444s and 450s are also software limited on 3rd rail...
I'm somewhat confused by the 2+1 seating. On the 700s they are needed to make the aisle wide enough to allow a wheelchair to move to the adjacent car and use the accessible toilet, and hence 2+1 is found near the wheelchair area. But 707s have no toilet, so what's the need for it?
Cramming in more standing passengers?
I Noticed platform extensions going on at Egham and Chertsey, I presume in preparation for 10 car trains.
Not directly for use by 707s though. It is the Reading 10 car project which will utilise 458/5s, replaced by 707s. The current 450s used on the Reading route will be internally cascaded to lengthen other 450 services, and replace the 456s on the Ascot - Guildfords.
The lengthening is supposed to be finished by May 2017, which seems feasible based on the previous 10 car platform lengthening works. Complete list is:
Ascot platforms 1, 2 and 3
Bracknell platforms 1 and 2
Camberley platforms 1 and 2 (to 6 car length only)
Chertsey platforms 1 and 2
Egham platforms 1 and 2
Feltham platforms 1 and 2
Martins Heron platforms 1 and 2
Sunningdale platforms 1 and 2
Virginia Water platforms 1 and 2
Wokingham platform 1 only
