BRX
- Joined
- 20 Oct 2008
- Messages
- 3,702
A DP railcard allows the holder & a companion both to travel at the reduced price.
It's clear that this is the case where both people have exactly the same ticket type.
However the railcard website isn't 100% clear on what the rules are if that's not the case.
For example, if the railcard holder has a return from A to B and the companion has a single from A to B, and they travel on the same service, can the companion benefit from the 33% off?
This is how it's set out:
Firstly, the "Information" section is badly worded, secondly it's not actually clear if it's talking about companions' tickets, and thirdly it doesn't qualify what "normally" means.
4. Conditions of use of the Disabled Persons Railcard
4.1. Only you and, where appropriate, the adult accompanying you, can use discounted tickets. The accompanying adult must travel with you throughout the journey.
4.2. When you renew your Railcard we may ask you for current evidence of your entitlement to it – if we do, your renewal might take longer to process.
INFORMATION:
Discounted price tickets purchased by a Disabled Persons Railcard holder should be issued for travel for the same origin and destination and should normally be of the same ticket type (example both Off-Peak Returns).
Railcard Terms & Conditions - Disabled Persons Railcard
www.disabledpersons-railcard.co.uk
