Mod Note: This thread has been split from the discussion on the Dovey Junction loop.
Gareth, I like your article on the 'Dodgital railway'. ETCS cannot in itself provide extra capacity on the rural railway. It was the additional and extended passing loops that did that on Cambrian.
Personally I think we should be looking at ETCS Level 1 LS (limited supervision) for perhaps up to 70% of the UK railway system. This is the method being used to introduce ETCS, network wide, in Switzerland during 2017 by completing the replacement of all their legacy track and vehicle transponders with ETCS standard equipment that replicates the functionality of the historic cab protection and warning systems.
It should be noted that the ETCS balise equipment is immensely more reliable and robust than our flimsy TPWS grids, although our legacy AWS magnets are pretty bulletproof, although expensive. The technique allows older rolling stock to to be far more easily modified to run on lines so equipped without the modern 'tight loop' traction and braking control systems necessary for a more sophisticated 'ATP like' standard Level 2 to function.
The genius of the SBB approach is in influencing the technical committees to incorporate the LS mode into the international specs so all modern fully fitted traction from all over Europe will in the future also be able to run over the entire LS fitted Swiss network as well as 'conventional' Level 2 lines. There IS Level 2 in Switzerland, but it is reserved for the ultra busy and high speed main lines dedicated to Intercity traffic and heavy international freight where its capacity benefits can be truly justified. The older traction, with only LS functionality emulating the legacy protecting systems, has no access to these lines of course. SBB worked very closely in cooperation with DB and SNCF in getting LS into the specs and I suspect these administrations also see a future in this technique for much of the secondary rail system.
Widely used French and Belgian balise-based systems are already very similar. The UK has not entirely ruled out LS but a report by RSSB dismisses it as a widespread method of improving safety, although acknowledged it could be a cost effective technique to apply ETCS in areas where the significantly higher costs of full Level 2, with all it's radio coverage, detailed infrastructure mapping and data maintenance difficulties were difficult to justify.
I think it might be justified to enhance safety by equipping all the intermediate plain line headway signals that were not fitted with speedtraps and trainstops as part of the TPWS project. Only signals protecting junctions were so equipped as well as bufferstops and certain speed restrictions. Rolling out LS in many areas (maybe as much as 70% of the UK network) instead of committing to network wide Level 2 could be an effective method of decoupling rollout from the wider signalling renewals and control centralisation programme with all its risks and funding challenges.
I think Digital Railway as a project had lost its way at one point but under the new leadership of David Waboso it's finding it's feet again. Sensibly, they've abandoned the Wherry lines L2 project which threatened to be an expensive repeat of the Cambrian, i.e L2 applied inappropriately to another rural route. Quick and inexpensive modular resignalling will be applied instead. LS would be a very simple and inexpensive bolt-on to that, and because of SBBs sterling work would be completely compatible with the new Stadler trains on order for Anglia.
