Ex LNER (and Grand Central) Mark 4 sets for TfW
Turbo004
3 Feb 2017
67025 is planned to go to Holyhead Tuesday morning. HD05 is planned to leave Holyhead Wednesday lunchtime if all goes to plan for Canton. Lack of available drivers at Holyhead is the cause.
Welshguy1048
6 Apr 2023
Prestatyn
Certainly looks better than the recent poor performance! Hopefully the spate of issues ends.
Not totally sure of what the plan is now to get HD05 done with regards to 5 car to be honest.
The latest plan I heard was its still planned to go but unsure of any timings, certainly was the aim to get HD05 to Canton tomorrow so if it doesn't go today potentially it could head down in the morning.
Thank you @sd0733
Dave
Thank you @Turbo004
Dave
sd0733
7 Nov 2012
Thanks for the update. Did wonder about what the spare crew situation would be on a bank holiday evening.
Lurcheroo
21 Sep 2021
Wales
Looks like 4 sets out today.
Interestingly HD06’s diagram usually has an ECS MANP-CREWE but will instead operator a 20:30 service departure from Manchester stopping at Stockport and Wilmslow.
I think this is a perfectly good thing to do, but does anyone know why it’s happening today?
Edit: think I may have figured it out, looks like usually a 4 car 197 arrives from Cardiff, splits and then 2 cars go back to Cardiff whilst 2 form the service to Crewe and the loco runs back ECS.
MP393
28 Jun 2021
North West
Yes your edit is correct. Occasionally the Loco + Stock will form that service in the case of a shortage of 197s, if only one unit goes up as 1W22 then the split doesn’t happen and the Loco works back to Crewe in service.
sd0733
7 Nov 2012
It did the same yesterday too with shortage of 197s
The 20:30 only goes to Crewe, with the path to Cardiff coming from Llandudno so having it as the Mk4 makes things much simpler without splitting in Manchester.
Topological
20 Feb 2023
Swansea
Is the longer-term plan for the Mk4 to work in service?
Presumably when we get the 5 car 197s on the Manchesters splitting becomes much harder. The 1930 from Manchester is still busy (at least at the northern end) so it would be a shame if the plan was for the 5 car that arrived from the south to continue to split into the 1930 and 2030.
sd0733
7 Nov 2012
Looks like it goes back to being a Cardiff service in the new timetable with the Mk4 going empty to Crewe too.
The way it works at the moment with it terminating at Crewe and a unit running via Crewe from Llandudno seems a better idea as it does mean 2 trains of higher capacity and less messing around in Manchester.
Personally I think the way it is with the empties and splitting is a real waste of resources and causes lots of problems but it seems for whatever reason that's the preferred way!
Caaardiff
9 Jun 2019
The ECS runs via Warrington for train crew route knowledge.
I think in the new timetable the Manchester-Crewe may actually be attaching to the Llandudno-Cardiff, although may be wrong there!
sd0733
7 Nov 2012
The 20:24 one runs via Styal, the 22:30 ecs runs via Warrington. There's other trains going via Styal or the later ecs around 23:50 could in theory cover the Styal bit.
It looks as if the one from Llandudno forms the Stopper to Shrewsbury in that timetable looking at the platforms.
To bring it back to Mk4s, the path is now showing for 67025+HD05 move tomorrow. https://www.realtimetrains.co.uk/service/gb-nr:71254/2024-05-08/detailed
Jez
22 Jan 2011
Neath
I think the long term plan was for the 19xx arrival from South Wales to still split even when its a 5 car. I think the 2030 is meant to be the only 2 car booked working out of Manchester to South Wales? So the 1930 would be the 3 car set after the split.
Anyway, good to hear all 4 diagrams were covered today. I noticed a 158 covering a 197 West Wales to Manchester service so looks like its the 197s we are short of today rather than MK4's.
craigybagel
25 Oct 2012
To be fair, given how much Crewe depot has expanded over the last few years there isn't much space to cut back on route retention any more for either Styal or Warrington with so many drivers to keep competent.
sd0733
7 Nov 2012
True, I know solving one problem causes another. Just a shame there's not an easy way of ticking all boxes and avoiding all the splits.
craigybagel
25 Oct 2012
Indeed - it's not like running the trains back separately doesn't cause headaches in its own right, even before you look at the inefficiencies of it all!
XCTurbostar
13 Sep 2014
Definitely won't as it is, it stops at Valley and Llanfair PG which aren't permitted Mk4 calls.
Thanks, I assume the set that finishes at Holyhead on a Friday will continue to be unused all weekend then!
Newp410
1 Jul 2023
Does anyone know if 1V93 on Saturdays will revert to a 67+MK4 from June 2nd?
Definitely won't. The 5th weekday diagram will likely come into play during the period of the June timetable (the one starting with 1W13) once HD05 re-enters service as a 5-car.
MP393
28 Jun 2021
North West
Thursday 09/05. HD06 breaking free from the Crewe-Crewe circuit after a few days and will end at Canton tonight. 4 diagrams out though so good to see.
67008 HD02
1V31 04:54 Crewe Cardiff
1W55 08:49 Cardiff Manchester
1V42 12:30 Manchester Cardiff
1W23 16:49 Cardiff Manchester
1K66 20:30 Manchester Crewe
67012 HD03
1W11 04:35 Cardiff Manchester
1V37 08:30 Manchester Cardiff
1W96 17:14 Cardiff Holyhead
67013 HD06
Empties ATC Crewe - Manchester
1V33 06:27 Manchester Cardiff
1W19 12:49 Cardiff Manchester
1V50 16:30 Manchester Swansea
67022 HD07
1V91 05:30 Holyhead Cardiff
1W57 10:52 Cardiff Manchester
1V46 14:30 Manchester Cardiff
1W65 18:55 Cardiff Manchester
Empties to ATC Crewe
mikestone1952
12 Feb 2011
Looks like 1K66 was loco hauled despite 1W22 running with 4 cars Tuesday and Wednesday (according to rtt) so is it diagrammed for some reason this week?
sd0733
7 Nov 2012
Looks to be yes, it's part of the Mk4 diagram and 5K23 the normal ecs isn't shown at all. Seems to be just this week though.
Okay, will it be booked Mk4 from the June timetable change? Thanks.
1st class fares are available to buy on the 10:30 and 18:30 from the June Timetable so hopefully it will be brought in then.
HD04 heading out on a test run tomorrow with 67015 https://www.realtimetrains.co.uk/service/gb-nr:71662/2024-05-10/detailed as its first full run as a 5+2 it should then re-enter full service on Saturday.
BillStampy
6 Jan 2024
Llanharan
My only issue I foresee is engineering works on the SWML redirecting the empty via the VoG, which isn't cleared for MK4s (I'm pretty sure). Which would mean atleast once every so often an entire week will be out of the question due to the redirection, unless they start it from Cardiff then the 1030 and 1830 would be fine.
craigybagel
25 Oct 2012
It's in the amendments for this week. I've no idea why though.
It's on the traincrew diagrams as a 67 from June, hopefully that will actually be the case!
Topological
20 Feb 2023
Swansea
Excellent news.
I would prefer there were going to be enough 197s that the service was able to go back to hourly between West Wales and the Marches and could be operated with 4 carriages. However, given where we are having the Mk4 does mean there is better capacity than currently operating so the diagram becoming Mk4 is a big positive.
sd0733
7 Nov 2012
The 3 Saturday diagrams are a bit different this week.
Should be:
1. 04:54 Crewe to Cardiff
12:52 Cardiff to Manchester
16:30 Manchester to Swansea
(Planned for 67015+HD04)
2. 06:27 Manchester to Cardiff
10:52 Cardiff to Manchester
14:30 Manchester to Cardiff
18:55 Cardiff to Manchester
(Planned for 67012+HD03)
3. 05:30 Swansea to Manchester
10:30 Manchester to Cardiff
16:50 Cardiff to Manchester
(Planned for 67022+HD07)
Of the other sets:
67014+HD01 at Crewe finishing exam
67020+HD02 at Crewe on exam over the weekend planned back out Monday 1V31
67025+HD05 spare at Canton planned back out Monday 1W57
67013+HD06 Having an exam at Holyhead early next week so the morning Holyhead will be a unit on Monday morning. Planned back out Thursday 1V91
Newp410
1 Jul 2023
The Vog isn't planned to be route cleared for them, so it will work like it has so far, on those weeks 5W13 / 1B13 will be a unit, changing to 1W13 at Cardiff.
