One is presumably the October revolution in Russia; is the second the entry of the USA into the war?
Your first, correct -- your second, no: the event in mind, is "related" to the correct first. (Continue to think, "calendar nonsense".)
It's the two revolutions in Russia in 1917 one called the March revolution, the other called the October Revolution.
The Russians were operating under I believe the Gregorian calendar whereas the western world had switched to the Julian calendar so in Russia the first Revolution which saw the Russian royal family deposed happened in Match but to the rest of the western world it was in February. The second revolution saw the Bolsheviks come to power is called the October revolution but I think may have happened in November.
Am sure Russia was still using a different calender then - Gregorian? So the revolution happened on different dates depending which one they were using. Think this why Russian Orthodox Christmas is a different date to say Greek Orthodox?
The following is a famous quote by Eamon De Valera
"It is indeed hard for the strong to be just to the weak, but acting justly always has its rewards."
Why did De Valera make this comment.
I believe this was in response to British criticism of the Free State's neutrality during WWII.
It's a long shot, but are they both (semi extinct?) volcanos which are still monitored by the authorities?
I know that there's a monitoring "station" on Etna - but I haven't heard of the other place, hence this guess.
Knocklayd isn't a volcano.
Etna is an Anglicised Irish girls name, anything to do with that?
Is it made of "volcanic/igneous" rock ?
I'm pretty sure that Etna is still active.
Is it something to do with filming locations. I'll go with Star Wars as they used Etna in Revenge of the Sith & they were filming in Ireland for the last one.
Not, I suppose, that both have, or have had, narrow-gauge railways in close proximity to them? Etna, the 950mm gauge Ferrovia Circumetnea (still running); Knocklayd, the 3ft gauge Ballymoney -- Ballycastle line (abandoned 1950).
As it's open floor here's a question from me:
What unusual distinction is shared by Mount Etna and Knocklayd (NI)?
Okay, I'll now pop in with what I think is the right answer (I have some family near Knocklayd so I hope I am not cheating...!)
Knocklayd's only unusual feature is that its summit is the convergence of ten townland district boundaries. Therefore, Etna must also share the same distinction, perhaps municipal boundaries?
In Northern Ireland, ten townlands meet at the summit of Knocklayd (clearly shown by Ordnance Survey mapping at point 311518 436392).[55][56][57] The townlands are, clockwise from north, Broom-More, Tavnaghboy, Kilrobert, Clare Mountain, Aghaleck, Corvally, Essan, Cleggan, Stroan and Tullaghore.
Map of municipalities in the province of Catania, Sicily, Italy
Similarly in Italy, the borders of ten municipalities meet on the summit of Mount Etna. These municipalities are Adrano, Biancavilla, Belpasso, Bronte, Castiglione di Sicilia, Maletto, Nicolosi, Randazzo, Sant'Alfio, Zafferana Etnea. The territory of Bronte touches the summit of Mount Etna from two sides, making this decimunicipal point one of elevenfold complexity, and thus evidently the most complicated geopolitical multipoint anywhere, other than the South Pole (see above section).
Would the answer be farting in his general direction?
Yes! A rebellious Exonian did fart at William and his army as they laid siege to the city. One of the earliest historical records of farting in England.
A method of communication understood in all languages.
I'll keep it local and fairly easy. What caused the Exeter Ship Canal (one of the earliest UK canals) to be proposed and built?
