NRE says
Anybody know what is wrong?
but traksy doesn't seem to show any kind of blockage. (1 siding at York shows "NOGO")Description
Due to a points failure at Huddersfield some lines are currently closed. As a result, trains may be cancelled, delayed by up to 20 minutes or revised.
Disruption is expected until the end of the day on Sunday 17 December.
Customer Advice for Northern:
Alternative travel suggestions
From Huddersfield:
Passengers can use Northern tickets on TransPennine Express services between Huddersfield and Leeds in both directions. You should change at Leeds for Bradford and Halifax, change at Mirfield for Brighouse. Alternatively, passengers can use the road replacement between Huddersfield and Halifax calling at Brighouse. All other services between Halifax and Bradford are expected to operate as normal.
From Bradford Interchange / Halifax:
Passengers for Huddersfield can either travel via an alternative train to Leeds, and board a TransPennine Express service from Leeds to Huddersfield, or use the road replacement service from Halifax. Passengers who require Brighouse can either use the road replacement, or board a train to Sowerby Bridge and change there for an alternative train to Brighouse.
From Brighouse:
Passengers are advised to use the road replacement services where possible, and connect with alternative trains from Halifax for Bradford Interchange. There is also an hourly service in each direction operating between Leeds and Manchester Victoria / Wigan Wallgate, calling at Brighouse. You should change at Mirfield for trains to Huddersfield, change at Sowerby Bridge for Halifax / Bradford Interchange.
Rail replacement transport:
To assist customers to complete their journey, road transport has been provided between Huddersfield, Brighouse and Halifax in both directions.
