LU/Elizabeth Line 4G update
JonnyM
4 Jun 2022
Morden, Surrey
Marble Arch, Lancaster Gate and Hampstead are live as of yesterday.
While this is good news, I was looking at the rollout map the other day. TfL have got a mountain to climb if they are going to keep their 80% of network covered by the end of 2024 promise. They really need to start speeding the rollout process up significantly.
mrmartin
17 Dec 2012
Another trip and still only L2100 10MHz on o2 in liz line stations.
Are other networks setup for better configurations than this? I cannot understand why they would put new radios in then only enable L2100?! Surely L2300 or L2600 could be enabled, or is this not supported by the cabling? I do understand NR3500 being much higher frequency, but L2300 is barely any higher than L2100.
James H
25 Jun 2014
We’re now in the purdah period before the mayoral election so things may stay quiet for a while.
FirstclassHST
28 Mar 2021
4/5G in stations only on Elizabeth line except Whitechapel, they said the whole line would be ready by spring meaning they only have like a month or so get it sorted lol
DC1989
25 Mar 2022
I'm sure they'll use astronomical spring meaning they have until late June :D
thomalex
25 Aug 2021
Any update on the Piccadilly line or Victoria line?
I note the map says the sections between Holborn/Russell Square and Oxford Circus/Euston should be live by the end of spring 2024 but haven't heard anything about these lines so far.
edgar13
25 Jan 2023
Think they've recently got a very short section done. Going eastbound on the Central line I used to receive signal on arrival at Holland Park, but over the past few days I've started receiving signal as we depart Shepherd's Bush (still nothing in the station tho).
pbin
25 Jul 2022
Currently on a soutbound Victoria line service. I believe it’s live between Euston and Oxford Circus in the tunnels although not at Oxford Circus and Euston in the Stations. Warren Street does appear to have service on the platforms.
JonnyM
4 Jun 2022
Morden, Surrey
A geeky, technical nugget of information I noticed on the westbound at Shepherds Bush is that Boldyn originally installed the small, round cells but these have been since removed and replaced with the usual square metal boxes. Any one know why? The outline of the small cells are still showing.
I’ve noticed that Boldyn are seemingly getting coverage in the tunnels first rather than the stations as previously. It kind of makes sense given that platform WiFi can be used in the station.
Gigabit
7 Dec 2022
United Kingdom
If they removed the station Wi-Fi they’d cut off some of the above ground stations they don’t plan to cover. For example Putney Bridge and East Putney have poor/no coverage in the walkways to the platforms. So unless they plan to install cells there - according to my FOI request it is a no - then they will create coverage holes.
I am not sure why they aren’t just installing cells at every station, this would be good for capacity if nothing else and they already did it with Wi-Fi.
Dent
4 Feb 2015
Are you suggesting that they blindly install cells at every station, even above ground stations which already have perfectly good coverage?
MrJeeves
28 Aug 2015
Burgess Hill
Yeah...?
Small cells are used heavily across cities for capacity as Gigabit pointed out.
In fact, most of O2's traffic in the City of London gets put through their dense network of small cells. Outside.
Gigabit
7 Dec 2022
United Kingdom
Well, yes.
But even failing that, do you not agree that at stations above ground which don't currently have good coverage in the walk ways etc it would be sensible to install cells there? They managed to do it with Wi-Fi more than a decade ago, so the strategy is slightly baffling to me. As I mentioned, East Putney, Putney Bridge don't have good coverage in the walkways or passages (with Putney Bridge having MNO masts installed very close by so it's an issue of building construction not lack of infrastructure). But TfL insist they won't cover these as the coverage is already acceptable (I don't believe it does pass for acceptable having used it on every MNO but I am sure TfL have a robust method).
TfL's response is that the MNOs should be able to do it on their own - but this is slightly contradictory as they are covering some stations that already have coverage and so are over-building anyway.
I am generally very supportive of the strategy but there are some odd holes in it. I wonder if in time these will be resolved but I am quite cynical. I am sure like most things it comes down to economics but I would have preferred to see an approach of providing coverage for above ground locations too where it is currently limited (and this was the original promise although TfL insist it wasn't despite my providing evidence of that).
We do run the risk of ending up in a two tier system, where we have excellent connectivity in the below ground stations and tunnels and far less reliable coverage and performance above ground.
But let's see.
ATS3
25 Apr 2024
This seems to be progressing at a snails pace
The infrastructure is already in, that isn't the issue for the Elizabeth Line at least, its just sorting out the software I believe. So they could switch it on tommorow but it would mess with the signaling system.
mrmartin
17 Dec 2012
I'm lost why it would affect the signalling system tbh. I thought the signals used fibre optic for communication?
MrJeeves
28 Aug 2015
Burgess Hill
The Elizabeth Line core uses CBTC which transmits instructions from the signalling system directly to the train via radio frequencies. I believe those frequencies overlap with WiFi and/or some cellular network bands, hence the concerns.
mrmartin
17 Dec 2012
Amazingly you are right, it uses 2.4GHz I think to communicate with the train.https://assets.new.siemens.com/siemens/assets/api/uuid:ae0a4c2a-efbf-4931-8f73-1fadc62b1b60/broschuere-trainguard-mt-e.pdf
Which would have issues with wifi but not with 4G/5G - but the wifi network on the train is operational even in the tunnels which could cause interference (plus people with personal hotspot left on). So I'm a bit lost to what the actual issue with this?
subria
23 Jul 2014
There are 4G bands in the 2100, 2300 and 2,600 frequencies (there are other bands in the 4G range I've not included.)
