New Mills Central landslip - 6 week closure
BingMan
8 Feb 2019
Sure, the issue with Northern RRBs is that often they just get what they're given. I used to commute on the Buxton line and there was a proper motley collection that turned out whenever the line was shut.
We nearly got stuck on a lane near Dove Holes station with a bus that was significantly oversized for the job.
Why don't the TOCs, or perhaps Railtrack, have their own fleet of buses operated by people who know the area.
High Peak buses have no difficulty running services around this area. To get to Chinley station you need a small single decker. Not the RRB I saw stuck there last week: a 100 seater coach more suited to motorway cruising than negotiating the Peak lanes
Railtrack stopped existing in 2002. Network Rail do not run trains so RRBs are out of the question. If you were a TOC and with different levels of disruption every weekend, how many buses do you need? What are you doing with buses etc when they arent needed? How do you know if local drivers are available as they surely work for other bus operators?
Killingworth
30 May 2018
Sheffield
Don't TOCs put this out to tender and then it's up to that company to rustle up buses as needed? Curiously Arriva had it for Northern, certainly until recently. Thus we may get a driver and coach from Kendal or Stoke to replace a train in the Peak District, using their own satnav because they've never been there before and haven't been given more than rudimentary route assistance.
If Andrews or another local firm have capacity, both coaches and drivers, and accept the terms offered all tends to go well.
43066
24 Nov 2019
You don’t seriously think there’s going to be a fleet of buses on permanent standby just incase a random landslip causes a closure somewhere on the railway network?
The issue as reported on here by insiders has been that TOCs no longer pay competitive rates for buses, hence they’re often simply not getting anyone willing to do what’s required for the price paid.
Llandudno
25 Dec 2014
Autumn - ouch. Thank goodness there are diversionary routes !
Probably because there are diversionary routes they aren’t busting a gut to fix it, if the landslip had been east of Chinley then they would move heaven and earth (!!!) to fix it …!
AlastairFraser
12 Aug 2018
Because, as another member said, they won't pay enough for most existing operators to bother running RRBs - let alone them buying a fleet of buses.
Network Rail pay TOCs a fixed rate for bus replacement as part of Schedule 4. Its the agreed compensation mechanism for the industry.
AlastairFraser
12 Aug 2018
Certainly, but the rail replacement contractors the TOCs use still offer a poor rate.
Dr Hoo
10 Nov 2015
Hope Valley
They can claim over and above if they believe and can prove that is the case.
Quite. I would have thought that the New Mills incident would be 'Sustained Planned Disruption' in Schedule 4 of Northern's Track Access Agreement, which is surely based on 'negotiation' rather than the formulaic bus costs under the arrangements for typical short pre-planned works.
175001
3 Feb 2007
Between Heaven and Hell
Yes.
Until 4 June according to Northern but probably later according to posts above.
Until the autumn at least. I'll nip into the drop in meeting on Thursday to see what's the plan.
Tonight's meeting was positive. It'll need a full blockade to rectify the fault but they believe it'll be sorted before the autumn
Killingworth
30 May 2018
Sheffield
From Network Rail's New Mills drop in event today (photos taken with their permission), work hopefully to be completed by September, currently intending to keep single track service to New Mills open, although details still to be finalised. Piles to be driven so may be noisy.
It's been slipping since at least 2012, a 2015 fix has not stood the test of time. Constant monitoring picked up new movement in 2021 and that has accelerated over the last year's exceptionally wet weather. An outline plan was already in preparation before the latest slip.
No costs given but over£5 million?
oddiesjack
11 Jan 2012
High Peak
When I went to the event, I spoke to the NR chap who was in charge of the cilvil engineering side of the project, and he told me there was likely to be a 4 to 6 week total blockade, probably in June/July. This would be so they could use engineering trains to supply some of the 50,000 tons worth of stone that will be required. Plus they would be able to use larger earthmoving equipment, without having to worry about keeping away from a live running line.
I do wonder how much of a "final straw" the rerouting of all the normally eastbound freight was during the week of the Hope Valley full blockade. One might have thought that the people who had just implemented a 5mph TSR at that location would have suggested to the short-term timetable planners that sending 10s of thousands of extra stone traffic that way was not a very sensible idea. Or maybe there was no discussions about this at all!
JKF
29 May 2019
I guess that 50,000 tonnes of stone won’t be coming from very far away then!
Killingworth
30 May 2018
Sheffield
To be discussed with TOCs is what I heard. Job done quicker with longer blockade or blockades - quite possibly more than one?
Killingworth
30 May 2018
Sheffield
There seems to have been a points failure this afternoon in the Hazel Grove area, all trains stopped for about an hour.
With diverted passenger and freight traffic across the chord the extra traffic can't be welcome.
Jamesrob637
12 Aug 2016
Naturally there's no Northern Twitter assistance since 14:00 today either
Mcr Warrior
8 Jan 2009
Think I'm right in saying that EMR have tweeted a few times about the incident today (Sunday) (most recently at 5.09 p.m.) suggesting that affected travellers should get their Delay Repay claims in. Link as follows...
Extract...
#EMRUpdate If you have been delayed by the points failure between Sheffield and Stockport today, you may be entitled to delay repay compensation. You can find more details here: https://eastmidlandsrailway.co.uk/help-manage/manage/make-a-delay-repay-claim.
We are sorry for any inconvenience this has caused.
furnessvale
14 Jul 2015
I went past the worksite yesterday (sunday), all appeared to be closed for the day.
far cry from my days in the civil engineers dept when we moved heaven and earth to reopen a (effectively) closed line. The cost of compensation to TOCs and FOCs, replacement busses, loss of passengers, not to say inconvenience to those hardy souls still using the trains, must surely outweigh the premium wages for sunday or night working.
Killingworth
30 May 2018
Sheffield
It was total bus substitution to New Mills yesterday so surely some preparatory work at least was going on?
furnessvale
14 Jul 2015
I passed on Redhouse Lane so I couldn't see the actual track, but the site gates were locked, all plant was stationary and no workers cars or vans were about.
If anything was happening, it all arrived and left by rail.
