Oxford - Torquay without Bristol
Stargull
1 Sep 2017
Hi
Yesterday I travelled Oxford - Torquay and back changing trains at Didcot, Swindon and Newton Abbot. I'm trying to book for 9th March, and planners seem to insist I go via Bristol. I can force via Swindon, but the route I get is still via Bristol.
Has something changed in the timetable, or am I just failing to put the right constraints into the planner? The main issue is that the routes via Bristol add an hour or so, which is a lot when doing that journey there and back in one day.
Thanks
Benjwri
16 Jan 2022
Bath
What route are you trying to get that is via Swindon but not Bristol? Except during engineering the two routes are via Westbury or Bristol. Unless you’re trying to change at Westbury as well as Swindon, which will almost definitely have a long wait, you are going to have to go via Bristol or Reading.
Stargull
1 Sep 2017
My itenary yesterday was Oxford - Didcot, Didcot - Swindon, Swindon - Newton Abbot (Via Castle Cary) - it's this later leg that I can't find for the 9th. Maybe there was some quirk of yesterday?
Benjwri
16 Jan 2022
Bath
Yeah the line through Newbury is closed this weekend, and therefore trains are diverted via Melksham or Bristol. When engineering is not happening you have to go via Reading if you want to avoid Bristol
