randyrippley
- Joined
- 21 Feb 2016
- Messages
- 5,141
I have never heard of, an National Hybrid bus.
not hybrid as in powertrain
hybrid as in mule, mixture, lashup, bitza, using bits of both as testbeds
That might explain, why the timetables have been removed from bus stops.Apologies if not the right thread, but does anyone know what's happening with the Preston - Lancaster service from late December (routes 40 & 41). I understand that the timetable is changing, but there doesn't seem to be any reference to these routes on the Stagecoach website?
Sadly i did not travel on it this weekend but i will once I've time i know there is only a small fleet that operates it.Could I ask what bus operated it? Normally it’s 15305
No problem. Thanks for responding. From memory there are only a few buses that are fitted with a tacho that is required for such a journey lengthSadly i did not travel on it this weekend but i will once I've time i know there is only a small fleet that operates it.
Yes it runs the whole route. WRT what runs on it you can get pretty much anythingLooking at doing the Stagecoach 42 from Lancaster to Blackpool. Does this bus run through the whole route? Stagecoach website lists the route fro Garstang but the PDF shows the full route. What usually runs on this route?
Hoping for double decker.Yes it runs the whole route. WRT what runs on it you can get pretty much anything
Its a through route Lancaster-Garstang-Blackpool and daytime & early evening it could be any of Morecambe's double deckers, though usually the older ones.Looking at doing the Stagecoach 42 from Lancaster to Blackpool. Does this bus run through the whole route? Stagecoach website lists the route fro Garstang but the PDF shows the full route. What usually runs on this route?
Was on the 42 in Blackpool yesterday. Was 10562 (Lakes Connection), this working which according to bustimes ran throughout:Looking at doing the Stagecoach 42 from Lancaster to Blackpool. Does this bus run through the whole route? Stagecoach website lists the route fro Garstang but the PDF shows the full route. What usually runs on this route?
