Maybe I'm missing the obvious but does it say whether the services along the Greenwich line would replace or compliment the services via Lewisham from Charlton?
The entire SE Metro timetable will be recast - With the current xx.24 & xx.54 Gillingham to Charing X (Via Dartford, Woolwich & Lewisham) Replaced by the Rainham - Luton (Via Dartford, Greenwich and London Bridge).
The Hastings line SE services will also have to be recast to incorporate the proposed hourly extensions to Ore (Replacing 1Fxx Ore to Vics) and I'd expect some retimings along the Maidstone East & Chatham Main lines.
One of the Hastings SE services already has a long turn around at Hastings, certainly enough time to get to Ore and back. It would seem that one reason that the Brighton / Victoria services went there is because the stop had to be taken out of the Ashford to Brighton services due to tight timings.
So a few musings from a Southern Metro prospective:
Proposed changes to train services between Caterham and London with improved journey times. What are these proposed changes? Don't want to lose the current 2tph along the Sydenham corridor.
New faster all day service between Caterham and London Bridge by combining trains at Purley. Will this mean axing the Caterham - Victoria services or combining the Tattenham fasts with one of the Caterham - London Bridge stoppers?
Norwood Junction will be served by Thameslink trains
This is good news as I mentioned earlier
No mention of the Beckenham Junction - London Bridge via Crystal Palace service.
And from a Thameslink perspective:
New all day train services are proposed to be introduced between Kentish Town – Central London (via Elephant & Castle) – Catford – Bromley South – Orpington. Doesn't this happen already Monday - Friday with the Sevenoaks services? Great if this is extended to weekends.
Proposed new all-day Monday to Friday and Saturday Thameslink service between Maidstone East and Cambridge Adding this to the existing SE service along the Maidstone East line would be most welcome particularly if they could stop at Bearsted
The only concern I have with only a two-track core is what contigency plans would be put in place in times of disruption (i.e. train breakdown in the core). I can't imagine SouthEastern stepping in with extra trains to Greenwich and Maidstone East to replace a failed TL service. Time to think perhaps of a second north-south link...?
I am surprised they are running 6tph to Hertford North all day, 4tph would seem sufficient with maybe another 2tph as far as Gordon Hill.
Easy. Turn services in the exclusive London Bridge Thameslink platforms. The low level can take the East Grinstead, Littlehampton, Horsham and Brighton services with Maidstone, Rainham turned on the high level platforms. I'd even suggest having the 4tph to Brighton on the TL platforms for turning releasing pressure on the low level.
One worrying thing is the Statement that Maidstone East service can't call at both Swanley and St Mary Cray due to tight turnaround times. Could the service be a bit fragile?
Yeh not good..... considering this service has been in place since the beginning of time. Also with no disabled access at norwood junction this could be big issue. They would have to ensure trains arrive into platform 5 for cross platform access for East Croydon connections.
Can Purley not be used more as a turn around point. Caterham has never needed 4 tph off peak neither has Coulsdon Town.
I look forward to casting my eye over this when I get home.TBH I would rather change at Norwood Junction (assuming reasonable connection time) than at East Croydon simply because EC is too overcrowded and generally an awful station IMO. If TL services could stop at Norwood, I would be very happy.
I am hoping the 2tph will continue along the Sydenham corridor to/from East Croydon (or Norwood Jnc) as LO only work to Crystal Palace or West Croydon which is no good to anyone hoping to make a connection at East Croydon.
Opps my bad Knebworth to Hitchin is the wrong example. The point stands though for journeys such as Potters Bar to Huntingdon, Knebworth to Arlesely, Welwyn Garden City to Biggleswade etc.
I do not understand how they can stop calling Gatex trains at Haywards Heath. This will significantly reduce the number of trains to Victoria this will leave about 3/4tph and you will loose the interchange as well.Disappointed that Seaford-Lewes is dropping from 3tph to 2tph in the peaks, and that the through Victoria services are under threat. There is talk of an acceptable 5-9 minute connection at Lewes off alternative London trains, but given how often these 'connections' are missed in the pm peak, this is not reassuring.
Also just read that Haywards Heath calls will cease, in the peak GatEx service, to be replaced by 'other Southern services'. This will not go down well, and the loss of HH as an interchange from/to GatEx is regrettable.
You have read it the same way I have. Back in December 2008 when the they started they told everyone affected by the change to change at Haywards Heath. It seems that has now changed... But if any Gatex no longer stop then they will be a netloss as currently all trains stop at Haywards Heath. Including the Thameslinks via Herne hill which will change into London bridge trains. Currently in the morning BML runs at full capacity so again in my head if any stops stopping then it is a loss?The consultation states 'other Southern services' will call instead, but this is intriguing as - during the peaks - all existing Southern services call anyway. The only new *Southern* services in 2018 appear to be a couple of additional Littlehampton-Victoria trains, which wouldn't compensate for the loss of (at least) 3tph GatEx.
The commuting populace of the Haywards Heath/Bolney/Wivelsfield Green areas is growing rapidly, and GatEx is part of the attraction. Being shifted onto Southern (with more stops), or Thameslink 700s (more space, but very few seats by HH) will not be well received.
Or maybe I've read the document incorrectly.
More to the point, if Gatwick Express services don't stop at Haywards Heath (and other stations) are they actually going to be able to path them non-stop at speed between Brighton and Gatwick Airport with the number of other trains that have to stop over the route?
On the other hand, trains from the main line (currently some Thameslink services) won't have to go via Redhill any more so perhaps that is where they think the capacity will come from.
Would their need to be an easement allowing travel via Finsbury Park?I would agree, from a direct service to a 23 minute wait is not acceptable. I wonder if circulation via Finsbury Park will be quicker.
The tables show a significant increase in *Thameslink* services from Haywards Heath, but of course these don't go to Victoria and, anyway, the consultation specifically states the ex-GatEx calls will be picked up by Southern services.
I do hope the consultation is not using 'Southern' as shorthand for 'GTR' in some places, but not in others. That would be very confusing.
That's what I thought, so cutting Gatex will be a huge loss at Haywards Heath.It's worth noting that the increase in Thameslink services isnt an increase in tph through Haywards but the current Southern Littlehampton and Brighton to London Bridge services transferring over.
Been reading this thread with interest. Will the Wimbledon loop trains still be going through the Thameslink core beyond Blackfriars...
Been reading this thread with interest. Will the Wimbledon loop trains still be going through the Thameslink core beyond Blackfriars or will they be terminating there. I know commuters using this service kicked up a fuss about this and won but surely this decison will be reversed once the rail planners realise the pain this can cause to the whole network if there are any issues? Also wouldn't they get more trains per hour if they terminated at Blackfriars? Seems a bit strange they fussed about this especially as they only need to walk across the platform to continue their journey. Most of them get off at Farringdon or City Thameslink anyway. The Catford loop line has needed more frequency badly but I can't see how it's going to work if there are any issues on the Wimbledon loop
