Top speed of various London Underground stock
LiftFan
27 May 2016
I was wondering the other day whilst on the Central line coming up to Epping, what London Underground stock is capable of the highest speed (Limiters disabled)? I have head stories of the A stock frequently hitting 75+ MPH, compared to the S stock only being able to go 62... I have also heard about the Jubilee sets having a high top speed although on the deep level trains the bouncier ride always does feel faster.
philthetube
5 Jan 2016
S Stock will only motor to 62, it will, however go considerably faster downhill.
Dstock7080
17 Feb 2010
West London
Certainly on the MET, on District/H&C maximum they will go is 48mph, restricted to 42mph in non weak-field areas.
Maximum permitted Line speed is currently 45mph (likely to be raised to 62mph upon ATC)
Acceleration rates and maximum speed are set by software from station beacons.
321over360
17 Jul 2015
There are videos on youtube taken on eastern ends of the Central Lines where the 92 stock does get up to some decent speed between stations, this is also evident in long tunnel sections like Mile End to Stratford, especially on the Eastbound tunnel as when the trains hit a vent the train carriages wobble about due to the speed with the 92s top speed also being 62mph, however alot of services come into platforms still at significant speed
video link:
https://www.youtube.com/watch?v=wg-PWLCbL9Q
Kite159
27 Jan 2014
West of Andover
The Victoria line feels quite fast on the long (ish) sections (Kings Cross to Highbury/Finsbury to Seven Sisters)
Central line speed is 100 kph in many open sections, although 92 stock has been restricted to 85 kph since the Chancery Lane derailment. The maximum line speed in the tunnel sections is 65 kph for most maybe even all.
Victoria Line max is 50 mph which is frequently achieved.
Jubilee Line max is 60 mph and this is frequently achieved although the trains do hang below this on uphill sections.
Northern Line max is currently 50 mph, in the open and in a few tunnel sections. There are plans to enhance to 60 mph although I'm not sure exactly where. The 50 is frequently achieved, in the tunnel sections this is between Kennington and Waterloo and between Highgate and East Finchley northbound only.
Picc Line I believe is officially 45 mph, although higher speeds are often reached. Oakwood to Southgate wb is a favourite, as is Hounslow West to Hatton Cross both, and fastest of all is Heathrow T123 to T5 web where 60 can be reached.
sk688
11 Sep 2016
Dublin
Pretty sure the Jubilee can get up to 50 , especially on the JLE
Out of intrest , what is the fastest speed DLR , Overground and the Waterloo and City trains would achieve in service ?
17 Aug 2013
For the ELL it's possible to briefly get up to 60mph (linespeed) between Anerley and Norwood Junction. Very very occasionally, a train may run at 70mph between Sydenham and New Cross Gate if it's switched onto the fast (misses out intermediate stations). Very rare though.
Within the tunnelled section, the highest linespeed is 40mph, and 378's have a published maximum speed of 75mph.
Mutant Lemming
8 Aug 2011
Some years back someone in a rush back with the last ety (72 stock) from H & W to SPK Dt reached 70 but also ripped out a few coping stones from the platform at Wembley Central on the way.
The 'Leaf Train' (RAT) was estimated at around 80 to 90 on the downhill from Chalfont to Chorleywood many moons ago - it could build up a good speed if it had a clear run and with not having to stop at Chorleywood. Officially it was supposed to trundle round at 15 mph to give an even spread of Sandite - though it never ran that slow as it would have ended up impeding the service.
Before more speed control signals were put in you could get up to 60 on the 'Cresta Run' between SJW and Baker 7. The practice of hammering down to Baker Street was frowned upon as the heavy braking required to stop often left platform 7 shrouded in a cloud of brake dust.
C stock seemed to be the most sluggish - even on night turns that took them fast up to Wembley Park they never seemed to reach a good turn of speed.
sk688
11 Sep 2016
Dublin
Thanks
gimmea50anyday
8 Jan 2013
Back Cab
Rapid acceleration is far more important than top end speed. I would imagine the trains rarely get up to speed due to the frequent stop start nature of the network, but it is interesting to see how fast these things can actually go!
sk688
11 Sep 2016
Dublin
That would be true for lines like the Victoria , Jubilee and lines like those , but for longer lines like the Met , top speed would be more important , especially on the fast lines , for example trains going fast from Finchley Road to Harrow , would be quicker if their top speed was 70mph ,rather than 62 as it is on the S8 units . I believe the A60 units were capable of 70 , as were the 1992 stock , but that is no longer the case
This was the case in the past, but trains are now sufficiently powerful that top speed can be routinely reached, particularly on longer sections. Lines like the Jubilee and Victoria have quite a few longer sections. A lot still depends on gradient though, particularly with the older fleets.
A 95 stock will quitehappiy reach 50 mph between Highgate and East Finchley nb on a steep rising gradient, which is quite an achievement.
philthetube
5 Jan 2016
That would be true for lines like the Victoria , Jubilee and lines like those , but for longer lines like the Met , top speed would be more important , especially on the fast lines , for example trains going fast from Finchley Road to Harrow , would be quicker if their top speed was 70 mph ,rather than 62 as it is on the S8 units . I believe the A60 units were capable of 70 , as were the 1992 stock , but that is no longer the case
You have to watch your speed on some sections in an S8, if speeds are increased there are other issues such as signal sighting times and track quality, gradients are also relevant, you could probably reach 80 south from Amersham but would you want to on that gradient.
I suspect that it would be possible to increase the speed of S stock by tweaking the computer, but probably with the loss of acceleration and as the majority of the work S stock do is not on the fast lines, probably not worthwhile.
rebmcr
15 Nov 2011
St Neots
S8s need to retain the same acceleration profile as the S7s, for pathing between Baker Street and Aldgate.
philthetube
5 Jan 2016
S8's have two different acceleration profiles, as did the A stock.
On the A stock it was switched between the two using the weak field switch, (flag)
On the S stock it changes automatically at Finchley Road, on both stocks it effectively it is changing the gearing. The S7's do not have this and so when one is taken to Neasden it's maximum speed is around 40mph
rebmcr
15 Nov 2011
St Neots
I thought Weak Field was something cut-in when already in motion and with the power handle in the highest notch?
Dstock7080
17 Feb 2010
West London
On LU trains, until '09 and S Stock the weak-field switch could not be reached by the driver while the train was in motion, it had to be set while stationary.
Dstock7080
17 Feb 2010
West London
Is the S7+1 still running about, or has it gone now? How did that manage to stick to time when it ended up on an Amersham or a Chesham?
There are two S7+1s still on the MET 21323/24, staying until ATC conversions finished and 21327/28 - this will be staying permanently.
Mutant Lemming
8 Aug 2011
Providing the flag hadn't been snapped off as was the case on many A60s
bluegoblin7
10 May 2011
JB/JP/JW
As far as the software goes (which is ultimately what governs the acceleration and braking rates on the S stock; in all cases they are capped performance wise) the S7+1s are pretty much identical to the S8s, so there are no performance issues.
...but could be reached by anyone travelling in the cab with the driver, or for that matter by an instructor with the train being driven by a trainee. I bet the flags on D stock were swapped over a fair few times by this means!
Nym
2 Mar 2007
Somewhere, not in London
And if you're tall and stretchy you could probably reach the flags on D Stock while driving, especially if you're driving left handed.
philthetube
5 Jan 2016
I never saw a train with the flag snapped off on an A60, they were removed on 59stock and maybe on others, thee was no reason to break one off, having it present improved performance.
Mutant Lemming
8 Aug 2011
The was a certain "eccentric/mad" (delete as appropriate) personage who used to 'collect' them.
Rumour also has it that this same person also had Sherlock Holmes tiles in their bathroom.
dmncf
4 Sep 2012
Nice one! I wonder if that Bakerloo line driver is the one who closes the doors about 3 seconds after opening them, regardless of whether passengers have finished alighting and boarding. Always fun when you're trying to descend the cliff onto the train at Willesden Junction with a buggy and a young child! :roll:
Mutant Lemming
8 Aug 2011
No - it was some time ago - He did lost his ticket after the Wembley Central incident.
LiftFan
27 May 2016
I honestly can't imagine a 72 clocking 70mph, must be a very bouncy ride...
