razourlight962
What are the main differences between the Gresley A1 and A3? I've been wondering for a while.
Result of 30 seconds on Google.The A3 was a modification of the original A1 design, and all of the surviving A1s were eventually rebuilt as A3s. Thompson designated the remaining members of the A1 class awaiting rebuilding as the A10 Class....
...Locomotives with the boiler rebuild were given the designation of Class A3.
This article is sadly lacking in one aspect of information.
After conversion of Great Northern to class A1/1 Peppercorn further developed the A1/1 for new construction. The new class became A1 and a further 49 A1's were built.
See here: http://www.lner.info/locos/A/a1peppercorn.shtml for details of what became known as the Peppercorn A1's. This web page details the history of all the LNER Pacifics via its various links.
And there's an article elsewhere on the site about Peppercorn A1s.
Just to round this up in one place, the main difference between A1 and A3 was the replacement of the 180 psi boiler with a 220 psi boiler. The locos already built were converted (over many years) while there were also new ones built after the start of the conversions.
As well as the new boiler there were a range of other modifications, one of which was the reduction of cylinder diameter by 1 inch. This seems contrary to the increase of power the new boiler provided, but I am guessing the old cylinder walls were insufficiently thick to handle the increased pressure. I don't know whether they just had liners inserted or whether fully new cylinders were cast.
A 180 psi boiler was rather low pressure for an express loco when the first was built in the early 1920s - the GWR had 225 psi boilers on their Star class some 15 years beforehand. Any ideas why Gresley didn't go for a higher pressure from the start?
The reasoning for sticking with the lower pressure for so long was, as is often the case, cost. Experience had shown maintenance costs rose significantly with higher pressure with more remedial work being required when each boiler was overhauled periodically at Doncaster works. ..... .
Which then, if true, begs the question: why did the GWR not reduce the BP of Stars and Castles - at least until the maintenance issues you bring up were sorted out?
I'm sure you are correct, but the higher BP will surely mean higher thermal efficiency - in other words, you will get more energy transferred to the train per pound of coal burned - other things being equal.
So you may have higher maintenance costs, but you will have lower coal consumption, and/or heavier trains hauled and/or faster haulage, even if your boiler needs more work on overhaul. (or shorter periods between overhauls).
The trick must have been to get the best combination, I suppose.
Interesting discussion though. Thanks for raising the questions.
Maybe something to do with the GWR having 4-6-0s instead of Pacifics so needing to get a bit more out of them?
Following on from Taunton's logic suggests a 4-6-0 can make better use of its tractive effort due to having better adhesion, so there is probably more reason to give it a higher boiler pressure and/or larger cylinders.
However the Pacific can have a larger firebox because there is no need to fit a driving wheel under it, so other things being equal should be better producing large volumes of steam over a long period of time.
Unfortunately for these propositions, and especially with apologies to 70014IronDuke (above), the use of WR-allocated Britannia 4-6-2s on the 1 in 36 South Devon banks was a nightmare,
Unfortunately for these propositions, and especially with apologies to 70014IronDuke (above), the use of WR-allocated Britannia 4-6-2s on the 1 in 36 South Devon banks was a nightmare, and eventually they were banned beyond Newton Abbot, some time after it was laid down that they MUST have an assisting loco between there and Plymouth, all due to slipping. They were put on the Cornish Riviera for a short while, to appease Riddles and his acolytes who sauntered over from 222 Marylebone Road to Paddington to see the "Rivvy" off at 1030 behind one, not knowing what the foreman at 83A had arranged. Doubtless an inspector strode forward to stand diplomatically between the long-suffering crew and "Mr Riddles, sir", especially on Tuesdays and Thursdays when it was a Laira turn.
Same experienced crews, same coal, same 4-hour-plus nonstop journey (with the big banks right at the end), and that Big Grate. Meanwhile, the Kings and Castles just carried on.
Perhaps at the time Swindon simply had more talented boilersmiths! Maybe the GWR water was better for boilers, and their generally excellent Welsh coal might also have made a difference to boiler life and repair costs.
All railways incrementally increased BP as they replaced and modernised their fleets because it was very desirable for the reasons you describe. The precise relative timings particular pressures were achieved by the different companies were probably subject to a lot of variables. 180 psi does seem particularly low for the time though. Perhaps there was always a conscious intention to uprate the locos later right from the beginning but only after exhaustive service proving at the lower risk lower pressure.
As to the Bulleids, well, I agree, they seemed to slip as standard procedure, at least in their original form. But again, I had never heard that the WR had banned them from this daily route knowledge turn.
Another reason for GWR locos not being allowed on the SR Exeter - Plymouth route could be that their width was "out of guage".
Good thing it was before the electrification then!the taller King lost its safety valve and cover to one of the massive road overbridges on the approach to the terminus!
I can recall 4932 Hatherton Hall, a good old 83B Taunton stalwart, on Taunton shed with scrape marks down the left hand cylinder cover. They were apparently a regular feature up at Old Oak Common on locos which worked down the West London Line and were, in theory, passed for certain Southern lines. Meanwhile, back at Taunton, there was a special engineering spec for the Barnstaple-Ilfracombe line to accommodate the 43xx which regularly worked over a Southern-maintained line.The larger GWR engines were very broad in the beam around the cylinders and front buffer-beam area, which could be particularly problematic with overhang on sharper curves through platforms on other railways, passing closely mounted lineside equipment such as ground signals, and for some types of bridge girders.
The King lost it's safety valve at Royal Oak because of the Paddington remodelling. The track was raised during the day and when it came back the safety valve bonnet was ripped off and the safety valve sheared. The resultant escape of steam so alarmed one of the well heeled nearby residents that the bomb squad was called out, which complicated the situation somewhat.
As well as the King, two HST power cars had their exhaust shields taken right off and several others had scores or dents. The following day I arrived for work at OOC and the Factory had the King in ready for examination.
The civils, naturally, had to pay for the lot.
