NorthWestRover
- Joined
- 24 Aug 2018
- Messages
- 1,472
I know this will sound silly as there is an obvious quick route, but is a weekly season ticket between Wigan and Crewe valid on any routes other than the WCML via Warrington BQ?
In particular, your season ticket isn't valid via Liverpool or Manchester, which I think might be what you're hoping to be the case.
However, additional validity can be obtained by buying the season ticket to a different destination. It looks like a Wigan to Goostrey season will add in validity through Manchester and Wilmslow, as well as Crewe, at the same fare as Wigan to Crewe.In particular, your season ticket isn't valid via Liverpool or Manchester, which I think might be what you're hoping to be the case.
Agreed, and apologies because I added much the same thought subsequently which likely coincided with the time you were making your post!However, additional validity can be obtained by buying the season ticket to a different destination. It looks like a Wigan to Goostrey season will add in validity through Manchester and Wilmslow, as well as Crewe, at the same fare as Wigan to Crewe.
