XC Voyager Refurbishment
sprinterguy
4 Mar 2010
Macclesfield
During the much reduced Covid timetable (services reduced by half) services were (allegedly) changed to double voyagers. Now we are past Covid, and customers numbers up again, accepting still not pre-covid, the double voyagers have disappeared. Some of the pre-covid services are back, but not many. Couple or Reading - Newcastle's per day. So surely doubling up in the short term, unit wise, is doable.
Most of the double sets were split to provide units to reinstate the hourly Manchester - Bristol service. The Crosscountry Voyager fleet is fully committed with the present diagrams.
I may be wildy wrong, but I seem to remember it was stated at the time as being too difficult/requiring too much structural work, to add windows to the former shop area and convert it to additional saloon space.
The exhaust runs up through that section of the body on one side, so any installed seating would have to work around that for starters.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Wouldn't it then be a good idea to relocate the cycle and large luggage spaces tlo the crumple zones so that the space they currently occupy can be used for seats?
Good luck trying to cut any extra window holes into a 24 year old Steel Monocoque body. Although the shop removal may have given XC some additional extra luggage and cycle space, there’s a lot not removed behind those panels including as mentioned above the Exhaust pipe, an Air Conditioning unit and various other bits of equipment - even the wall panels along the cycle side weren’t changed. I think modifying the Voyagers to that extent is a no-goer now.
class397tpe
22 Jan 2022
Cambridge
The baseline for XC improvements really ought to be for every service to be a double Voyager; internal refurbs would be an added bonus!
I think you’d need all the class 220, 221, and 222 units to double up every service. IIRC there were 53 diagrams pre Covid, less diagrams now.
If you took on all 221s and 222s, and reformed the 222s a bit, you’d have:
34 4-car 220s
4 4-car 221s
40 5-car 221s
4 4-car 222s
17 5-car 222s
4 8-car 222s
Which they could aim to run as:
Around 35 diagrams of 9-car 220/221
Around 2 diagrams of 10-car 221
Around 4 diagrams of 9-car 222
Around 5 diagrams of 10-car 222
Around 3 diagrams of 8-car 222 (single units)
So around 49 diagrams of full doubled-up units total. Give or take a bit with the 9 vs 10 car combinations based on availability.
Gives 4 spare 220/221s and 4 spare 222s (one of which is 8-car).
Obviously this is pie in the sky and the DfT will never approve the funding.
Energy
29 Dec 2018
Shop would be difficult but I'm curious how structural the toilets are. Cutting holes for windows is obviously a no go but you could potentially slot in a space saver toilet and luggage storage in the current disabled toilet inside space, then stick seats in the current luggage stacks.
Something like this could be interesting:
Towers
30 Aug 2021
Also worth bearing in mind that IETs have seats installed into windowless areas intended for luggage stacks; indeed they’re even within the inward taper of the bodywork! So, given how poor the capacity is on Voyagers, while it isn’t ideal it’s not without precedent and would gain some additional seating.
superalbs
3 Jul 2014
Exeter
I don't see why they couldn't have a 442 style lounge area, would provide some casual seating for shorter journeys.
Danfilm007
5 Jul 2015
34 4-car 220s
4 4-car 221s
40 5-car 221s
4 4-car 222s
17 5-car 222s
4 8-car 222s
Would it be more valuable to split the 8 car 222s into the 4 car ones? So you have 21 5 car and 4 7 car which could be used on fixed formations?
Wolfie
17 Aug 2010
They are utterly dreadful refurbished or unrefurbished. These 4/5 car units need to replace the 170s and a whole new 800 fleet ordered for the long distance services. 6 car minimum and 12 car for peak services. They need to stop messing around and get on with it.
The Avanti ones were far from dreadful. Refurbished they are decent albeit that l admit X-Country's stock needs some TLC. What there isn't is enough of them.
800s are dire and absolutely no more should be bought.
Energy
29 Dec 2018
I doubt XC would be able to get all the 220, 221 and 222s.
Taking on the 221s and playing around with the layout is a bit more realistic.
Depends on how much of the toilet you can remove. If it's all of it then I don't see  unreserved windowless seating as a big problem.
Passengers (who care about the window) on longer journeys can change seats when they become available.
Obviously windowless seats shouldn't be on new stock but it's better than no seat
BanburyBlue
18 May 2015
Great - so as per usual, Birmingham to the South Coast is the poor relation.
Wolfie
17 Aug 2010
They’re reliable and comfortable and provide a much much smoother ride than the Hitachis. The only real problem is there just aren’t enough of them.
Given a choice of a relatively well padded seat of a Voyager or an 800 with its upright hard as stone seat and those constant shudders and bumps for 5 hours my money is on the Voyager every time
Having said that I could really do without the interior of my train looking like a child was let loose with the pink crayon, what are they thinking, it’s just horrific
Balanced and fair.
Towers
30 Aug 2021
Some decoration of the walls, as per the scenic vinyls in the bogs, would help relieve it a bit.
I'm here now
26 Aug 2023
Cornwall
I think that they just need to shave off the seat width and give a longer fold down table. I do hope that the current seats are retained in some form because 80x class style seating is brutal in comparison.
Towers
30 Aug 2021
Might make the tunnels into New St look a bit better :lol:
That’s the best bit of the journey!! :D
I fear they won’t be; as someone said further up the thread, the seat backs & sides are absolutely battered and really wouldn’t be befitting of any halfway decent refurb if left as they are. I can’t imagine them being individually hammered back straight again but you never know I suppose!
Energy
29 Dec 2018
New seats are coming.
The current ones are battered. I reckon it'll be the pendolino refurb seats.
I don’t suppose any of those will be returning back further to Winchester / Eastleigh / Southampton? Or are we sadly confined to Hourly on the XC timetable from now on? :rolleyes:
Extensions are definitely not mentioned. This has also been posted in another recent thread somewhere.
Russel
30 Jun 2022
Lichfield
I'm not sure lack of windows in the old buffet area is as much of an issue as it initially sounds, have a look around on most trains, a good proportion of passengers don't look up from their phones or tablets from when they get on to when they get off...
Personally when I've watched a film on my tablet on trains in the past, I've searched for a seat without a window just to avoid the glare.
It could even be marketed as an area for working!
MCR247
7 Nov 2008
I thought there was a reason they didn't put seats there. Apart from lack of windows.
Whilst the lack of window may not be a problem for some passengers, I think the issue might be that it doesn’t really help the case when it comes to weighing up the costs and benefits of the work. I don’t think the work would be cheap, it would likely make the refurbishment take longer whilst still inevitably being a bit of a bodge job. A lot of work for a few extra seats without windows in a vestibule area. I dread to think how it’d go down in the media/on social media, with it being a double whammy of “trains bad” and “waste of taxpayer/farepayer money”
irish_rail
30 Oct 2013
Plymouth
Maybe try doing a 4 car set all the way from Birmngham to Plymouth before feeling too hard done by yes? That's 3 and a half hours stood by a toilet. At least on the south coast route, most people are not on board for quite so long. In my experience there are plenty of doubled up voyagers on the south coast route anyway. Yes, it appears a busy route, BUT, most of the journeys are around about an hour or so. The south west route has a lot more 2 or 3 hour journeys on it. But we still have not enough double sets and feel the poor relation out west.
TT-ONR-NRN
30 Dec 2016
Farnham
It’s no different to saying the West is the poor relation of GWR while 5 cars form the majority of South Wales services though, which you often do. I think the truth is plenty of XC services are short formed and additional capacity is badly needed everywhere.
BanburyBlue
18 May 2015
I haven’t seen a double voyager on the South Coast for months.
