jonty14
Er this is a rail forum so bias is allowed towards railways.maybe the public did want the railway re-instated... but would it have been cost effective?
the truth is that most guided busways so far have been short sections to give buses a quick way through traffic bottlenecks (Crawley, Ispwich, Edinburgh)
so far the only 2 operational busways that cover ground that could be covered by rail are the cambridge and luton ones.
In the case of cambridge, being a deeply rural area albeit with large commuter flows I doubt there would ever be the passenger numbers to make it a viable rail route. As for luton all that would've been feasible as a rail route is a detached shuttle due to the layout and topography of the junction with the main line. It would've cost millions just to re-align and rebuild the junction.
I am sure (or would hope) that the councils did their due diligence to cost out all the options against projected passenger flows.
To castigate the busway option as cheap and nasty shows that you have a natural bias towards rail.... probably rail or nothing.... I wonder what the passengers would say given the option of rail or nothing? I'm sure they wouldn't choose "nothing"
As I said above the system used in luton and cambridge has worked well in other parts of the world... so the problem isn't the system or idea of busways in use.... it is the poor execution in the construction..
all a guided busway is is a rubber tyred tram.... seeing as though Paris has managed for years with rubber tyred trains I don't see why people are so anti busway when the only other viable option is "nothing at all"
Again this is a rail forum. If you are anti rail go on a bus forum and stop being provocative to rail supporters.I stand corrected on when the line closed to passenger traffic. However I do object to the slanderous comment you make about my views.
I have already stated in previous posts that I believe in horses for courses, but I WILL defend busways against the "rail at any cost" lobbyists such as yourself!
The original intention of this thread was to discuss what has gone so wrong with this busway that it needs remedial work already.
We fortunately live in a democracy. This means we elect politicians at both a local and national level. We then have to trust that they will use due diligence when taking decisions.
Whatever OUR views, the politicians in this case decided that a GUIDED BUSWAY would serve the needs of their residents better than a light or heavy rail solution.
Just because this particular busway has continually needed remedial work since being built does NOT make busways a flawed concept. ALL infrastructure needs maintenance and repair to keep it running at A1 condition.
Anyone who argues that the problems with the Cambridgeshire Busway's construction shows that busways are flawed has to then argue that RAILWAYS are also a flawed solution.... or have you forgotten what happened after the Hatfield crash when huge chunks of the rail network ground to a halt when it was discovered that the rails were full of cracks... perhaps at that point we should have ripped up all the rails and turned them into motorways? I think not!
