1521 York to Manchester Airport (Saturday, 16th February)
Xenophon PCDGS
17 Apr 2011
We had chosen this as our return journey and had seat reservation tickets booked A19/A20 and this was supposed to be a service from Newcastle leaving from platform 9. However, this train started from the bay platform 1 at York. Does anyone know the reason why this service did not start from Newcastle?
From Real Time Trains
This service was cancelled between Newcastle and York due to an issue with the train crew.
You can't use the public open data feed as a reliable, authoritative, descriptive source.
The reason given on internal systems is that a driver wasn't available but the underlying reason for that isn't given.
Trainfan344
13 Oct 2012
Not always reliable but usually are. Especially in this case as confirmed by your post.
Intermodal
3 Nov 2010
I wonder how long I can make my location on this f
Transpennine turn many trains back at York and Darlington that are bound for Newcastle. When I was in Tyneside IECC the other day they said it is happening 6 or 8 times a day. The general reason is due to late running that happens in the Manchester area but there are other reasons too.
Intermodal
3 Nov 2010
Thank you for the responses. Do you think that the next day trip we hope to make, this time from Manchester Airport to Durham (and return) on the TPE Newcastle service, should be one service to be put on the "back boiler" for the foreseeable future?
I wouldn't say so. There are lots of services that run from York to Durham should it get cancelled.
Xenophon PCDGS
17 Apr 2011
Would tickets booked at Manchester Airport for journeys from Manchester Airport to Durham (and return) only be valid for use on TPE services? We always book seat reservation tickets at the time of booking on longer journeys, being in our mid-70s.
a_c_skinner
21 Jun 2013
The railway is bound to get you home and I imagine you'd be told to take the next service to York and pick up TPE from there. I don't know if "they" could make you wait for the next TPE if you had an advanced purchase TPE only, but I suspect it is most likely they would not. Conditions of Travel say if your train is late you have to get the next one of the same company for advance tickets, but don't deal with cancellations as far as I can see. If you bought an open ticket it will be valid by any train company and any permitted route.
Intermodal
3 Nov 2010
This is technically true however you may find reality is a bit more lenient than that. I wouldn't let it put you off t ravelling.
