1980 Glasgow Aberdeen Mk2 coach formations
Dunblane80
12 Apr 2022
Morpeth
Between the class 40/47 mk2c Aberdeen to Glasgow and the class 47/7 mk3 formations was there a class 47/4 mk2d formation?
If there was what was the typical formation? If not what was the typical formation for mk2c sets circa 1983 to 84?
Cheshire Scot
24 Jul 2020
North East Cheshire
Whilst I don't personally recall Mk2c sets on this route (although they may well have been) Mk2d sets did certainly feature.
43096
23 Nov 2015
The accident report (https://www.railwaysarchive.co.uk/documents/DoT_Nairns1982.pdf) into the 1982 Forteviot level crossing collision/derailment gives the formation of the train (1335 Glasgow QS to Aberdeen) as:
Class 47/4 loco
Mark 2A BSO
Mark 2E FO
Mark 2D TSOT
Mark 2D TSO
Mark 2D TSO
Mark 2D TSO
Mark 2D TSO
Cheshire Scot
24 Jul 2020
North East Cheshire
Class 47/4 loco
Mark 2A BSO
Mark 2E FO
Mark 2D TSOT
Mark 2D TSO
Mark 2D TSO
Mark 2D TSO
Mark 2D TSO
1980/81 all sets Mk2 Vacuum Braked stock - likewise Glasgow/Edinburgh to inverness with Mk1s on Inverness / Aberdeen
no trace of 81/82 marshalling book.
1982 and 1983 marshalling books shows the above as the standard formation - Mk2A BSO and the rest Mk2D or E - other than the one Mk3 set with DBSO. In the same era Glasgow/ Edinburgh to Inverness was transitioning from Mk2 VB to Mk2 a/b/c, and Inverness / Aberdeen then a mix of Mk1 & Mk2 VB stock.
hexagon789
2 Sep 2016
Glasgow-Aberdeen broadly went:
From late-50s - Mk1, sets were load limited from May 1962 for the accelerated 3-hour schedules on two workings each way.
From 1977 - Mk2Z/Mk1 (Mk1 usually just the buffet car/full brake but some TSOs/BSK etc did appear at times)
From 1980 - Mk2Z + one Mk3A push-pull set (Mk3 set made available through adjusting the E&G set diagrams)
From May 1982 nominally (older stock continued to appear through the year) - three Mk2D/E + one Mk3A push-pull set. The Mk2 sets had a non-air-con Mk2 brake vehicle in the formation.
From May 1984 - timing load reduced one coach for accelerated schedules. (Track improvements coupled with the load restrictions enabled an overall cut of 8 mins.)
From May 1985 - three Mk2D/E push-pull sets + one Mk3A push-pull set. Glasgow to Aberdeen now fully push-pull worked.
There were some slight changes to set formations within those periods. For instance - the initial Mk2 air-con push-pull sets had a Mk BG in formation, five were painted in the new ScotRail livery, these were withdrawn from sets the following year.
