Why did/do the 319s have front doors but the 700s don’t require them when they run the same route?
There's egress space on the Thameslink Core Route, out the side of the Trains, so the front door isn't needed. (Also why a lot of the section from Farringdon to St Pancras doesn't have ballast).
Its the same reason Lizzy-Line train's, Class 345s, don't have front end doors, there was side egress routes built into the tunnel.
717s do need them for Drayton Park to Moorgate as the Tunnel is Single Bore. So the only egress between stations is out the front or rear of the train.
