3rd rail and OHLE
DJC_158
20 Sep 2006
Melksham
hello all,
this may be a stupid question, but i have always wondered whether trains that are either powered by 3rd rail or OHLE would not run during a thunder storm.
im not an expert on Electric trains, but i would have thought that they would have some form of a safety cut system in the event of a power serge or during a thunder storm so that it cuts out all power safely.
cheers
dan
Nick W
5 Nov 2005
Cambridge
The OHLE cables aren't high up compared to high-voltage electric pylons so I doubt the risk is taht great.
Surely lightning hitting a line will do more damage to the line than any frying it may cause to a train.
O L Leigh
20 Jan 2006
In the cab with the paper
No problems. Both the supply systems and traction have safety cut-outs to deal with power surges.
A lightning strike to the OLE is more likely to cause physical damage to the infrastructure than any electrical interference.
one TN
LucaZone
24 Feb 2006
West End, Surrey
As the electrical wires are totally isolated anyway, wouldnt this prevent a strike that hits a pylon from connecting with the wires? So the strike would just earth straight away.
Respite
30 Oct 2006
Staffordshire
I've only ever heard of a few lightning strikes on the actual wires & this did operate the safety cut off's as well as blow a few insulators.
Dennis
8 Aug 2005
Trowbridge
Lightning affecting signalling seems to be a more common problem - every time there's a bit of thundery weather a pile of delays seem to be attributed to this.
Respite
30 Oct 2006
Staffordshire
Yep modern signalling only seems to require a slight surge & thats it relays fried! Mind You I always had reservations about pulling levers attached to metal point rodding & 100's yds of steel cable in the middle of a thunder & lightning storm when I worked manual boxes :sad10: :)
AlexS
7 Jun 2005
Just outside the Black Country
Water Orton seems to blow every time...
Given the flash new signals at Codsall have already set about failing semi regularly, i wonder what the next thunder storm will do to them.
