dave59
- Joined
- 28 Jul 2010
- Messages
- 120
It's an altered schedule, asides from incorporating a Lockerbie stop (which adds 4-5 mins as its in the middle of a 125mph section), you have:
Yep it's returned back to Glasgow, with passengers having to change trains onto the next one.This particular train appears to have made it as far as Carstairs only before reversing and going back to Glasgow Central.
5 min Carlisle dwell
10 min Penrith dwell
5 min Oxenholme dwell
5 min Lancaster dwell
Crewe call (with a 5 min dwell), so the Glasgow runs in a different path south from there and pathing adds about 24 mins to the schedule.
The entire schedule has 57.5 mins of pathing allowances. Remove that but leave the engineering allowances and you get a better idea of what a normal schedule with these stops would be.
You also have the extra long dwells at 5 stations (usually everything except Preston and Carlisle is 2 mins, with P & C being 3).
I will absolutely concede it is a ridiculous schedule, but a closer look at the allowances and dwells at least demonstrates how it is so long.
Admittedly the closest normal equivalent is the 0800, which arrives at 1354 but has a different stopping pattern and goes via Birmingham, so not truly comparable.
Strikes today, so any vaguely normal timetable out the window.It looks like they've all but given up completely. An altered schedule from an already altered and extended schedule. And in this case it was Carstairs return only. When I first saw the timing I thought it was (single) Class 50 hauled. Thanks for the explanation.
That's because it didn't see Polmadie as was booked to outstable at GLC.Yep it's returned back to Glasgow, with passengers having to change trains onto the next one.
The problems were concerns at the state of one of the Pendolino's pantographs looking very worn (not sure why it wasn't noticed before it left Polmadie?). It was also running on reduced power and none tilt.
