67023 and 027
Jonny
10 Feb 2011
The 73/9s have AAR multiple working fitted so they can run together with 59s, 66s, 67s, and 69s.*
The advantage for the 67s is that unlike the 66s they can provide HEP, so it would be possible for the 67s to run on their own if the couplers and other relevant interfaces were modified. We're probably just going to have to wait and see though.
* = technically the Chiltern 68s too, for completeness
Which begs the question, is an additional crew member needed to supervise the ETH/HEP in the Class 73 with a 66, but would a 67 be monitoring the 73's ETH/HEP from the driver's desk?
cj_1985
6 Mar 2010
You could probably add the class 70 to the compatible AAR list
Additional staff member isn't required when it's double-headed by class 73/9. No reason one would be required on a service with a 67 up front coupled to and working in multiple with the 73
Jacob Porrett
28 Jan 2022
Telford
This afternoon at Arlington.
Not my photo.
I really like that. Livery suits it well. I have been told that the sleeper duties aren't progressing very well at the moment so they might do scrap/stock/unit movements instead. They won't appear on any freight duties though.
The_Train
2 Jun 2018
Any idea when 023 will go for a new paint job?
It's at Crewe IEMD because it has been a very naughty boy in Scotland and needs a couple of hammers taking to it! Presume GB will hold back consideration of a repaint until it is working correctly
43096
23 Nov 2015
67023's repaint will happen once 67027 is released from Eastleigh and is working properly-ish.
Jacob Porrett
28 Jan 2022
Telford
Will they still be called Charlotte and Stella or will GB rename them now as they are under a new FOC?
MCR247
7 Nov 2008
Something doesn’t look quite right about that.. I’m guessing it will obviously get yellow ends since it isn’t compliant.
There is a yellow panel. Personally if I was Gbrf I’d just make the whole front yellow instead of any orange, but not have the yellow area go any wider than the light clusters so you can’t see it from the side but they seem to like rectangular yellow panels
XCTurbostar
13 Sep 2014
Strange that they didn’t use the opportunity for new BMAC lights like the 66s
John Bishop
15 Nov 2018
Perth
If these are dedicated sleeper locos, I’m surprised they weren't painted into CS blue/ teal such as the previous 67. In any case, this is certainly an improvement on 67023 at the moment in that horrific faded Colas yellow.
