Good for you. I've always advocated that we should have the chance to take a peek over the other side of the fence from time to time as well as inviting the neighbours around.
Yes a lot of drivers moans about signallers are unfounded, but then I'm sure the opposite is equally true. However, while I can understand why I get held outside of Liv St from time to time, I can also see the times when I'm delayed without cause because of the actions of the controlling signaller (usually on approach to various CCTV crossings). If the signaller had a better understanding of the routes they control, what us drivers see and how we have to react then perhaps such incidents could be avoided.
For example, there are quite a few CCTV crossings on a certain section of our route that are all controlled by the same workstation. Quite often we are forced to react to a YY aspect on approach by braking because we cannot yet see the next signal. This is all down to how quickly (or otherwise) the crossing and the protecting signal have been cleared. This is such a problem for us having to brake for one crossing, accelerate, brake for the next crossing, accelerate and brake again for the third crossing (usually down to a red) that it has been picked up by our performance manager and raised with Nitwit Rail.
Life would indeed be easy if it was only the signals we needed to look out for. It's all the stations, "tango's", crossings, irregular stopping patterns, idiotic members of the public, passengers, managers, stray livestock, flooding, snow, wet beds, irregular signalling sequences, detached droppers, train despatchers, changing lighting conditions, washed-out signals, low rail adhesion, train faults and failures, abusive people, trespassers, drunks and fallen trees that make things interesting.
O L Leigh
