It's over an hour long, can you remember when it was mentioned?
Very early on, it's from around 3:00.
I think people are missing the point. This instance was of a train exceeding the permitted line speed by a significant margin. The examples in Germany are of trains normally running below line speed but running up to line speed in the event of late running - that is not the same as what happened in this case.I have heard similar about ICE 3 being allowed 330 to make up time, so I'm sure it is possible is permitted in Germany in certain circumstances at least on high speed lines, though they'd have to have a means of adjusting the can signalling to allow for such otherwise it would trip everytime.
But such is not allowed in the UK, as many drivers have posted in the past while there is some tolerance if it is found that drivers are routinely exceeding the speed limits they will be up for a meeting with "tea and no biscuits". Some more modern fleets will even give the game up themselves - Class 185s for example will send a text message if the overspeed threshold is reached (103mph)!
I know it's not the same, and I did ask how it could happen that even if the speedset failed, the driver allowed speed to climb to at least 20mph over the permitted before noticing but I never got an answer to that.I think people are missing the point. This instance was of a train exceeding the permitted line speed by a significant margin. The examples in Germany are of trains normally running below line speed but running up to line speed in the event of late running - that is not the same as what happened in this case.
It didn't 'fail', it was disengaged through an unfortunate combination of circumstances, seemingly with a contribution to those circumstances by the driver. As for why the driver didn't notice the excess of speed, who knows?I know it's not the same, and I did ask how it could happen that even if the speedset failed, the driver allowed speed to climb to at least 20mph over the permitted before noticing but I never got an answer to that.
Sorry, someone said it failed in a post above and I erroneously assumed that was the case thenIt didn't 'fail', it was disengaged through an unfortunate combination of circumstances, seemingly with a contribution to those circumstances by the driver. As for why the driver didn't notice the excess of speed, who knows?
Is that not a common feature then? Not fitted on any AT300/Class 802 fleets?Some more modern fleets will even give the game up themselves - Class 185s for example will send a text message if the overspeed threshold is reached (103mph)!
Overspeed trips or text messaging?Is that not a common feature then? Not fitted on any AT300/Class 802 fleets?
The SMS alerts.Overspeed trips or text messaging?
I can confirm that the 33s were fitted as mentioned, when you reached 85mph the amps would drop right off with the power handle left in position, then when the speed dropped to below 80mph, IIRC, the amps would increase again. This would have been in the early eighties.This was based on my understanding that class 33s were fitted back in BR days
I believe 444/450s to be the same which would make sense of course - I've seen mention of some form of speed limiter on 444s but not any detail as to exactly how it works in practice.Class 350s had a form of speed limiter fitted. It wouldn't let the speed increase (under traction) past 100mph, and then later 110mph. But you could leave the power controller open and the unit would keep the maximum speed (100 or 110mph). You'd obviously have to watch it on a falling gradient as it wouldn't stop the speed increasing past that.
My feeling also, but presumably there is a good reason why that was not the case and speed allowed to climb to 20mph over linespeedI would have thought that by 130 it would have felt a little too fast, surprised it got all the way to 145.
As a passenger I've always felt like on on electric it feels like they're just getting going when they hit 125 as in it feels like there's still plenty left in the tank to go faster.Realisation time plus rectification. How good are the 802 acceleration at these speeds?
That sounds remarkably like software developers telling you "It isn't a bug, it's an undocumented feature".It didn't 'fail', it was disengaged through an unfortunate combination of circumstances, seemingly with a contribution to those circumstances by the driver. As for why the driver didn't notice the excess of speed, who knows?
But if driver is TPE and only used to 100moh class 185s, it may be very very early in his 125mph driving career and his experience of what 125mph "should" feel like may be limited.I would have thought that by 130 it would have felt a little too fast, surprised it got all the way to 145.
This all sounds a bit alarming to me. Was there an investigation and were the crew found to be at fault in any way? How dangerous is travelling at that speed and what’s the safely margin built in above line speed
If it happened where I'm fairly sure it happened, somewhere between York and Northallerton, the line is as straight as a ruler and flat as a pancake so the danger would have been basically nil as the driver would have no doubt spotted it once they began to bring their speed down for the slightly twisty tracker north of Northallerton (and actually I bet they had a call booked at Northallerton so that would have slowed them down anyway).
Perfect about as flat and straight as you could ask for really! Obviously an issue that needs to be looked at and action taken to avoid it happening again but it pretty much couldn't have happened in a safer location really!In the video Dennis does actually claim it happened between Northallerton and Thirsk.
The fact that a track-geometry induced derailment was unlikely doesn't mean it was in any way safe. The railway isn't built or maintained for use at 145mph and the additional stresses of operating at that speed are significantly more than the 20mph excess over the PSR might have you believe. Would have been rather nasty for the knitting to suddenly come tumbling down all over the train, for example, or for the train to derail through a set of points that disintegrated.Perfect about as flat and straight as you could ask for really! Obviously an issue that needs to be looked at and action taken to avoid it happening again but it pretty much couldn't have happened in a safer location really!
Sure, it 100% shouldn't have happened and I hope that steps will be taken to make sure that it cannot happen again because it clearly isn't safe. But equally, personally, I'm not going to be losing sleep over it happening in that location. I can think of other locations where it would be far more alarming for something like that to happen.The fact that a track-geometry induced derailment was unlikely doesn't mean it was in any way safe. The railway isn't built or maintained for use at 145mph and the additional stresses of operating at that speed are significantly more than the 20mph excess over the PSR might have you believe. Would have been rather nasty for the knitting to suddenly come tumbling down all over the train, for example, or for the train to derail through a set of points that disintegrated.
Not a train driver let alone one that drives high speed services but surely 5mph over the speed you're expecting wouldn't be that noticeably faster? I agree that getting all the way to 145 is impressive but 130?
I guess as @irish_rail says the driver may well be used to running at 100 so anything faster feels new. As somebody who spends most of their life at 125 you get a feel for how quickly the ole masts are going past, and can tell the difference between 120 and 125. I’ve never reached 130 so can’t say for sure but I reckon I would know by then something wasn’t right.
They spoil everything nowadays.As stated, it was accidental. Speeding to make up time is not allowed.
