Abellio Greater Anglia Class 755s (Regional Trains)
Railperf
30 Oct 2017
Was going to report a flawless performance on the 755s today..but currently sitting at Bury after an engine shutdown as we were on the verge of departing.
Engines restarted but not moving yet...
Edit: finally moving 10 late after a couple of false starts.
Edit 2. The guard has just come though apologising for the delay - claiming it is a problem with one of the engines. A driver bringing this in earlier said the TMS had been flagging up engine temp warnings. However it had run okay despite that.
We have plenty of padding in the schedule..so not too worried about arriving late in Cambridge unless the issue reoccurs starting from Newmarket or Dullingham. Strange that all 4 engines shut down. Can they not simply isolate the faulty one from.providing traction until it cools down?
LAX54
15 Jan 2008
So, with a 156 on the Sudbury all day, a 156 on the 0540 Colch to Peterboro, (402) the 0627 to Lowestoft is 156419, and the 170 on the 0645 to Lowestoft, ALL other services have to be a 755 :)
LAX54
15 Jan 2008
I've noticed Journey Check is showing the Ipswich-Peterborough trains as 2 carriages instead of 4, so getting close to seeing them on that line.
First time I've been on a Class 755 train from Cambridge to Ipswich, and seen the next one towards Cambridge at Chippenham Junction also being a Class 755.
Peterboro: 6th Jan 2020.
Sudbury 13th Jan 2020
1 x 745 to Liv St 8th Jan 2020 (0740)
Tim Regester
3 Jul 2019
I just had a long chat with my brother and explained the issues encountered on GA lines and track circuits with the new Stadler Class 755's. He raised two points, on a course last year to get his railway signalling electronics and systems knowledge up to scratch, the other signalling engineers on the course stated that the signalling systems on NR are not always being maintained by engineers with real experience of how the systems work and just read circuit diagrams and don't carry out sufficient testing. So the problems may be due, in part, to poor maintenance by subcontractors working for NR.
The other point mentioned was that the Class 222 Meridians had similar issues on EMR where trains disappeared off track circuits and this was proven to be a track circuit issue not a train issue.
This sort of makes sense. BTW despite him working now at a University he does signalling for Heritage rail organisations so keeps up to date and his degree thesis was on ATO and Rail signalling so it is his area of expertise.
ge-gn
5 Dec 2014
What a load of rubbish. The railway is maintained often over and beyond what is required in the standards by staff, who are hugely experienced in their local districts.
Grumbler
27 Mar 2015
Then why don't the train detection systems work properly?
Mag_seven
1 Sep 2014
here to eternity
If true somewhat worrying given the safety critical nature of signalling systems.
Railperf
30 Oct 2017
Yes there are a couple although it makes no difference to performance.
Which ones? 417 was playing up on Monday with fluctuating engine temps. The Ipswich driver said it was still running. I'm told drivers cannot isolate engines. But once the alarms start going off - a call to someone in diagnostics is required to help go through the TMS and reset everything to carry on.
dk1
2 Oct 2009
East Anglia
Sorry I pay little attention to numbers. Just another unit to me unless its 419 which seems to be the black sheep of the fleet.
Railperf
30 Oct 2017
Performance wise, the superior acceleration on the 75mph sections of track gives the 755's up to 40 second head start over the older 170's. Unfortunately half of that seems to get lost under braking as drivers get to grips with the brakes - and probably often because the train is well within time - so no need to drop the anchors lol.
Railperf
30 Oct 2017
No worries - I often forget to check too lol! I
Adrian1980uk
24 May 2016
We've all got to remember this time next year we'll probably not be talking about the 755s as they'll be putting in a shift day in day out. Probably be talking about the 720s and infrastructure improvements
Tug
2 Aug 2019
Does having 2 engines & a missing bogie on the 3 car sets mean there is only bogie driven rather than the 2 on the 4 car sets?
Tug
2 Aug 2019
Both axles driven on 2 bogies for both 3 & 4 coach units?
Seems expensive (v important to GA!) to have bogies capable of handling twice the diesel power available on the 3 coach units.
ivzem
15 Aug 2019
Potsdam, Germany
https://www.stadlerrail.com/media/pdf/feabmu0819e.pdf says yes.
Presumably it would've been more expensive to order two different designs, both of them nonstandard; also don't forget the 3-cars could be extended to 4 cars in the future and having as many common components between the two as possible is useful for maintenance.
Chris125
12 Nov 2009
They aren't just diesel units though - the 3 and 4-car units are much more, and equally, powerful under the wires IIRC.
samuelmorris
18 Jul 2013
Brentwood, Essex
If anything the 3 cars are noticeably more powerful on the juice than the 4s.
I should expect so, with one less vehicle and two less engines to carry around. They are actually rated at higher acceleration on electric, 1.3ms^-2 rather than 1.1 for the 4-car, in other words 0-40 in 13.75 seconds.
TheEdge
29 Nov 2012
Norwich
From a standing start in Ipswich platform I've hit 100 before going under the A14
Roger B
16 Jun 2018
Gatley
Thanks for this info. Can you point me to somewhere where I can see acceleration rates for other rolling stock - ideally for all DMUs and EMUs. Many thanks
